Question about Nintendo Super NES Console
Why is my super nintendo screen skipping? and what do i need to fix it or why is it doing this? i have purchased a new rf switch and it is still messed up.
  • 291 Answers
why is my super nintendo screen skipping? and what - n64_komodo_av_cable_tmb.gifWell try the avcables for super nintendo instead of using the rf switch then.
Posted on Oct 11, 2011
Super nintendo
Original-Style Super NES RF to VCR Hookup
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the VCR. Note on Sharp TV/VCR Combo
After the system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen. You are ready to play!
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck using the Stereo Audio/Video Cable.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Feb 10, 2013 | Nintendo Super NES Console
Snes red horizontal lines
When hooking a super Nintendo or an NES system or a sega genesis system to a digital tv you need av cables for it to work then instead of using an rf switch
Sep 30, 2012 | Nintendo Super NES Console
My super nintendo has green lines that keep running down the tv screen from top to bottom. Everything else works fine and you can still play but the green lines are really annoying.
Well the reson why there are lines in it becuase its starting to wear out the connections or if you are using the av cables or an rf switch it might need a new av cable or and rf switch then.
Jun 23, 2011 | Nintendo Super NES Console
My nintendo nes does not work on my samsung lcd tv. it just has a grey screen but no picture. it works fine on my friends LG tv
Blank Screen
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.
Other Screen Problems
Make sure you are using only licensed accessories with your system.
We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
Check all of the system connections to verify that they are firm and correct.
For AV connections
Remove the AV cables and reinsert them with a slight twisting motion
For RF connections
Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
If the above troubleshooting doesn't fix the problem, see below.
What to do if Troubleshooting Doesn't Help
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product. If you simply need to order parts or accessories, you may want to check out our Online Store. Nintendo's Online Store still carries many parts and accessories for our older products.
Jan 08, 2011 | Nintendo Super NES Console
I haven't played when super nintendo in awhile, but when I turn it on the screen is black and has white lines going up, whether there is a game cartridge or not, the same thing always happens, I've cleaned...
For AV connections
For RF connections
Dec 16, 2010 | Nintendo Super NES Console
Ive not played my super nintendo in at least 5 years. i hooked up to my tv and turned it on. the main screen for all my games were fine but when i went to play all you could see was the background. there...
For AV connections
For RF connections
Try cleaning the game packs out with quips and rubbing alchoal.
Nov 27, 2010 | Nintendo Super NES Console
I need a schematic for the rf switch for SUPER
You probably won't find a schematic for it at this point. You can probably use Google to look for pictures of the RF switch on the Super Nintendo, taken apart, though.
Nov 08, 2009 | Video Game Consoles & Games
Snes -horizontal white lines and buzzing noise
the best bet is to obviosly try another rf cable or try anothe snes unit.
Jul 06, 2009 | Nintendo Super NES Console
Super nintendo will not play Tetris
Clean the game with q tips with alcohol on them, then, tune the tv to channel 3 with a remote.
Mar 17, 2009 | Nintendo Super NES Console
Nintendo Super NES Console Logo
209 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
