Question about Perrin and Rowe Rohl Bath U-5388 ; U 5388 Ceiling Shower Arm 4 inch
Perrin and Rowe, Mayfair Series.- how do you take the perrin and rowe handle apart. The top of the handle has a ceramic disk inserted that says "Hot" or "Cold" and I am not sure whether to force the disk off to find the screw"?" to remove the handle. Also, how is the nickel skirt removed. The parts are listed in the following wesite; I can't read "prints" well http://www.nortesco.com/downloads/perrinrowe_spareparts.pdf
    Problem Solver:
  • 5 Answers
The disk is glued on, but no need to remove. The entire section below the handle spins off, but most likely not by hand (hot did, not cold). I used channel lock pliers and some wood strips that I fabricated to prevent damage to the finish. You then need a thin 17mm wrench to remove the valve. I presume you are having problems turning the cold water handle? Seems common, I am working on it now, looks corroded so I am soaking it in 50/50 vinegar and water.
Posted on Nov 15, 2013
  • Fritz Dogbolter
    Fritz Dogbolter Nov 22, 2013
    Just to let you know, this worked perfectly for me. No new parts needed. Careful with the vinigar, soaking a nickel finishe can be harmful so limit contact time.
  • Anonymous Oct 03, 2017
    The advice was very helpful but cant seem to separate the valve from the threaded housing that the valve screws into. Guess it just needs penetrating oil?
2 Suggested Answers
  • 81 Answers
SOURCE: Perrin & Rowe Mayfair kitchen sink faucet sticks
I wwould suggest contacting the source importer for this one, Rohl, at 1-800-777-9762. Be prepare with as much ownership information as you can. As a high quality high end faucet, all parts will most likely have to be special ordered so you want to know that what you are ordering is what you really need.
Posted on May 29, 2010
New Perrin and Rowe hand sprayer leaks on assembly
Hello, It is a defect in the product, you must replace the and sprayer.
Sep 15, 2013 | Rohl U.4759APC-2 Perrin and Rowe Bar...
My plumbing supply house was suppossed to order my Rohl shower set up with cross handles (RA4914 & 4912). Instead he ordered the lever handles. My sink faucet (RA1408) was ordered correctly with the...
Nice.
Paying that price for your shower faucet, I would think the supply house would work with you on that. eBay shows cross handles so they are available.
The plumbing supply store should be able to order what you want.
Sep 12, 2017 | Rohl Perrin & Rowe Exposed Tub or Shower...
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Feb 02, 2011 | Perrin and Rowe Rohl Bath U-5386 ; U 5386...
Atriflo oberon kitchen tap dripping. looking for manual to fix along with source of any washers / parts i may need
Isolate hot and cold suplies in turn and to identify which valve is letting by. Ring Atriflo (Perrin & Rowe) on 01708 526361 (Mon-Fri) to order the correct valve. For the Oberon the parts are Hot: 9.13145; Cold: 9.13146, but check with them first - they are very helpful and on the ball.To access the valve remove the handle (unscrew manually); remove the handle coupler (size 14 hex. bit) and gently unscrew the chrome bell-shaped valve shroud. (A mole wrench gently applied, with suitable padding to avoid dinking the chrome, does it nicely.) All will then be revealed.
Jan 18, 2011 | Microwave Ovens
Mar 30, 2010 | Home
Continue to blow fuse MDL-6 1/4 for a Rowe-AMI Ti-1 jukebox
HAI, IN A/C VOLTAGE INPUTS THAT AREA TO REPLACE THE DISK(POLYSTER,CERAMIC) . THE DISK DOES NOT BLOWS BUT INNER SHORTS TWO POLARITY.
Jun 26, 2008 | Audio Players & Recorders
Perrin and Rowe Rohl Bath U-5388 ; U 5388 Ceiling Shower Arm 4 inch Logo
2,425 people viewed this question
Top Perrin and Rowe Home Experts
Donni Steen
Tom Chichester
Are you a Perrin and Rowe Home Expert? Answer questions, earn points and help others
