Question about Kenwood Audio Players & Recorders
KENWOOD UD-70 MIDI SYSTEM: When system is switched on a loud bang sounds through speakers & 'PROTECT ' starts FLASHING on AMPLIFIER DISPLAY. although everythings stopped working,cd player,cassette deck & tuner still seem to be functioning .Checked the speaker cable connection and all other cable connections as per manual,re-connected everything but still not solved the problem. Any solutions would be very much appreciated.
SOURCE: Protect
I know I'm finding lots of old posts about this JVC model MX-KB30 "PROTECT" problem but - I FIXED IT!!!! 8-) Daugter had the same difficulty after a series of power outages. Figured it had something to do with the speaker circuit board. Decided to look for a reset on the board itself. Not sure that I found one, basically becuase there was not a perception of a button pressing down, but the "PROTECT" cleared and the sound is coming through the speakers again. The sterio works fine. First - as when working on all electronics - unplug the unit and make sure all static electricity has been discharged before working on it. You will need a small jewlers philips screw driver as well as a mirror for looking down on top of the electrical components. Remove the cover of the sterio surrounding the sides and top of the unit - there are screws on the sides, top and around the edges of the back fo the unit related to this piece. You do not have to remove any other pieces. There will be a circuit board attached to the back center of the unit that has a black cable running to the headphone plug and the speaker connections are also running through this board. If you face the front of the unit, looking at the sound circuit board from the right side, there will be a small black - square looking - voltage regulator (I think that's what it is anyway) that you will see some voltage information and some switch setting pictographs (along with the numbers 1, 2, 3). On top of this black unit (here is where you need the mirror) there is a square hole that looks down inside this unit as well as a round hole that you will see white plastic inside. Using the jewlers screwdriver, carefully press on the white plastic once or twice (I couldn't tell that it had pushed down) particularly becuase I have no clue how sturdy this piece is. With the cover still off the unit, plug it in and make sure the "PROTECT" message has disappeared and the speakers are working again. That's exactly what I did and the darn thing started working again. Maybe I just got lucky, but this is a nice sounding unit and it would be a shame to see folks toss it away for such a simple fix if that is indeed what did it. Enjoy!
Posted on Apr 23, 2007
SOURCE: bang & olufsen stereo unit 9300
Following advice from Simon at Avaservices.co.uk, I double checked the speaker switches and found that whilst handling the speakers I had moved one switch to line.
This I corrected and then double checked the cable concealment to one speaker and found that possibly one of the carpet strip tacks may have moved the cable position whilst refitting the carpet and caught the cable?
This was repositioned and the system tested. Absolutely terrific!
Thanks all round!
Posted on Feb 19, 2008
  • 146 Answers
SOURCE: We can't get the power to come on.
Make sure that everything is plug into the right spot. If the amp comes on and nothing else, I will check the power cords. Also check the power buttons for each unit and make sure they are on. Also listen for a click sound from the amp when you turn it on. You will here it about 2 to 7 seconds after you turn it on with the main power button. If you do not here it, then you have a problem with the amp. One of the channels is bad and you will need to take to a repair shop for repair.
Posted on Nov 17, 2008
  • 263 Answers
SOURCE: no connecting wires..????
They seem to have special leads to connect them together pretty expensive ....
http://cgi.ebay.co.uk/KENWOOD-B-B5-Connector-Hi-Fi-component-cables-lead_W0QQitemZ120453267078QQcmdZViewItemQQptZUK_AudioTVElectronics_HomeAudioHiFi_Tuners?hash=item1c0b92fe86&_trksid=p3286.c0.m14
Posted on Aug 03, 2009
SOURCE: My Kenwood UD-500 Shelf System doesn't switch sources,
did u ever solve this problem? I have exactly the same problem?!
Posted on Oct 07, 2009
Kenwood ud 700 protect
When a radio or an amplifier goes into protect mode there are only 3 things to consider: your power wires my not be connected properly, your speaker wires may be shorting out somewhere or your speaker/s might be going out or totally done.
Foraudiogeeks.com
Apr 13, 2016 | Kenwood Car Audio & Video
Power amplifier kenwood, power led blinks, no sound
There will be noaudio coming out , if the protection circuits is
sensing a fault or overload , just to protect your precious speaker
from further damage ( or the amp itself ).
These needs servicing.
Aug 13, 2012 | Kenwood Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
Hi I have a Kenwood HI FI System with an amp that says protect can you help,Thankyou
unhook all speakers to the amp and the power it up..if it still says protect..then the outputs inside the amplifier are blown...you will need to have a tech repair it
Jan 04, 2012 | Car Audio & Video
Keeps flashing Protect
there is a short in one of the speakers,or the outputs in the amp blew.
unhook the speakers and try it.
if the protect stays on,the amp is blown.
in the winter when the defrost is run on hot,it can overheat the amplifier.
Jan 12, 2010 | Kenwood KDC-MP205 CD Player
Kenwood kdc-bt742u flashing protect and no sound
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Dec 17, 2009 | Kenwood KDC-BT742U
Kenwood Midi M-97/M Switch power on and after a few seconds i get a protect message appear on A-97 amplifier and it blocks use of the system. -Paul
this is prob because of a wrong connection between speakers connections + to + - to - check all speaker wires are correct with no shorting out between + & -
Steve
May 15, 2008 | Audio Players & Recorders
Kenwood mpe system flashing protect
"PROTECT" means that the unit's thermal protection units were activated, which in turn cut off output power to the speakers. The causes for this vary. Usually, it's a problem with the impedance load that the speakers present to the power amplifier inside the receiver. Occasionally, the circuit acts up and activates itself, or playing the unit too loudly has blown a fuse. First, check all the user servicable fuses. You'll find their location and amperage rating in the user's manual. If they're broken, replace them. Make sure that none of the bare wire from any speaker is touching any bare wire from any other speaker. If the unit still won't power up, then I'm afraid you'll have to take it into the shop for evaluation by a qualified repair technician. Best of Luck.
Sep 14, 2007 | Kenwood KDC-MP335 CD Player
Kenwood kac x621 kenwood kac6402
May i suggest removing the equilizer unless you can adjust the settings for each amp seperatly. The amps themselves will allow you to add bass boost and treble boost. I think the problem your having is trying to run to much bass through your system causing it to distort badly.
Feb 25, 2007 | Kenwood Excelon KAC-X621 Car Audio...
414 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
