Question about Lutron Diva Dv-600P Light Control By
How do you remove the existing wires from the DIVA-600P light control. They are not screwed in, rather they are pushed into the back of the dimmer
You have 'quick connects'
Next to hole where wire goes in, is slot for small screwdriver.
Push screwdriver in real firm while pulling wire.
Posted on Nov 13, 2010
How do I get wires out of leviyon 6843 dimmer switch
Nick, Sounds like the wires are pushed in to the back on your switch(quick connect system), there is small tab in the hole located next to the wire hole, use a small enough screw driver to push the internal tab and hold in/down until you have wire pulled from connection.
Check the attached links,instruction and guides, the 2nd video shows the removal closer to the end. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Light Switch with Dimmer
secret to undo backwired electric outlets switches
How to wire switches
How to replace electrical outlets using QuickWire Push In Connectors
Apr 23, 2016 | Electrical Supplies
I have a 600 watt 1 pole Diva dimmer controlling five 65BR30m for a total of 325 watts. With the slide control all the way to the top, the lights will not reach maximum brightness (as compared to...
First of all, in general, dimmers (even at their highest setting) cause the lights to dim even a little bit. If you are doing a 1-for-1 comparison, you may notice a difference - but honestly, it shouldn't be THAT dramatic that you're able to notice it.
My first suggestion is to double-check the model number. There's a version of Diva with a "G" in the model number (DV-603PG-) which was designed with a lower-high-end light level than normal (designed to guarantee extra energy-savings).
If the model number checks out, my next suggestion is to upgrade to a spec-grade product (like an NT-600-WH). The commercia/specification grade products have a higher high-end than the residential grade products. It still will dim the lights a little bit, but will be better.
After that, I suggest calling tech support at 1-800-523-9466 for more suggestions. Its a free call and they're available 24/7.
Apr 17, 2011 | Lutron DV-600P Diva Single-pole 600 Watts...
The light on dimmer no longer lights ad the switch does not work
Your best solution is to call the company's tech support number at 1-800-523-9466. Depending upon the details they may be willing to replace it for you.
Jan 17, 2011 | Lutron Diva Dv-600P Light Control By
Our lutron dimmer switch only has a yellow light and no green light. It obviously will not turn on any of the lights it is connected too. We have flipped all the breakers and everything is good. All the...
I would call their tech support center for clarification, because what you descirbe doesn't immediately make sense. The only light that a Diva has should be a yellow glow through the back of the plastic. If you're talking about a green light, then maybe you mean a Maestro, but there's no yellow light on a Maestro... it's making me think you may have a different manufacturer.
Regardless, call tech support to figure it out. They're at 1-800-523-9466 and available 24/7.
Dec 15, 2010 | Lutron Diva Dv-600P Light Control By
The slide on the diva does not dim anymore - what happened?
Sometimes a hellacious lamp blow-out or lighting strike can knock out the dimming element in the device. Call their tech support line at 1-800-523-9466. You may want to suggest that they upgrade you to a 1000-Watt dimmer so that the issue doesn't happen again.
Dec 08, 2010 | Lutron Diva Dv-600P Light Control By
Have lg-600p with 2 black wires and 1 green. do i wire the 2 black to the black circuit wires and the green to the negative?
Simply, no...but it's almost never simple is it?
In household wiring (AC) there is really no positive and negative, they are hot and neutral and ground.
Wire black to black, yes. But the green one is the ground and if you wire this one wrong you've got much trouble.
In the box where the dimmer goes there should be two of each wire, white, black and bare.
Join the two whites together and tuck them into the box.
The bare wires and the green screw all go together. Cut yourself a length of spare bare (ground) wire, marrette one end of this together with the other two bare wires, turn it round the ground screw in the back of the box and tighten it down, then join the other end to the green screw of the dimmer. This is a "pigtail" and it makes things easier in many situations. Tuck this into the box.
Last, join black to black.
Aug 09, 2010 | Lutron LG-600P Lumea Single-pole 600 Watts...
In the past couple of years, Ive had4 Lutron
they are cheaply made. not hard to chang to a flip switch.
Mar 04, 2010 | Lutron Diva Dv-600P Light Control By
I have a trimatron dimmer which has a black, red, green and another red wire labeled 3 way. My box has two black , white, red and groud wire. this room has two seperate light switches that control the...
When you take the existing switch out of the wall, the existing switch will have one black screw and two gold screws. The wire that is connected to the black screw of the existing switch (probably on of the black wires from the box) connects to the black wire on the new dimmer. The other two wires (one black and one red from the box) that are connected to the two gold screws on the existing switch will connect to the two red wires on the new dimmer. Basically, wire from black screw goes to new black wire and wires from gold screws go to new red wires.
Sep 27, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Lutron Diva Dv-600P Light Control By Logo
159 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
