Question about Zefal Bicycle Air 1 Floor Pump
I have a old zefal maxi pump, and it doesn't pump air any more. I was thinking if there is a way to repair the pump like replacing some rubber or leather plunger. Where could I buy the kit and how to replace the failed part?
How do you use it?
there is a little switch looking thing that has to be lifted up from the pump then insert the valve into the bike pump and then puch the switch/lever back down and start pumping then to take off lift lever and quickly take pump off valve otherwise you will lose air you just put into tire
Mar 13, 2013 | Zefal Bicycle Duo 821 XLT Frame Pumps
I dropped my maxi cosi foray and the handle bar doesn't snap where it should anymore?
Hi
You should e-mail the USA customer care team at crelations@djgusa.com to discuss with them the possibility of repair.
Oct 29, 2012 | Maxi-Cosi Foray Trail Stroller
I have the whirlpool model WTW495OXWD and it wont spin or drain,
see this causes:
It spins, but doesn't pump
drain line is clogged fix it,some sock is inside, take pliers and remove, if you can you need to remove the agitator, the propeel of pump can be defective replace.
It doesn't spin or pump
frozen pulley pump replace
It pumps, but the water returns
improve the drain line. if mayor that 4 inch cut of the diference, is a lower install air/gap siphon break assembly
Jun 21, 2012 | Whirlpool Washing Machines
I can't get my Zefal pump to seal onto my Pestal tires. The pump head constantly pops off. Do I need to return the pump?
If it is a dedicated presta pump, there should be a threaded cap on the head where it attaches to the valve stem - it has a hole through it to allow the stem through. Tighten that stem slightly and it should compress the rubber enough to hold on. But don't tighten too much or it will be hard to get off.
The head holds on with a rubber donut under that cap. By tightening the cap, the donut gets compressed and closes the hole tighter.
Oct 17, 2010 | Zefal Cycling
I have a Zefal HP frame pump. I'm trying to inflate a tire with a Presta valve. It just won't inflate. It doesn't latch onto the valve and seems to big for the valve body. Is there a diagram available...
Let's hope you didn't force it and snap the plastic point off.
Most Zefal pumps come with a reversible head that can adapt to either Presta or Schreader (like on cars). You unscrew the barrel at the working end of the valve, carefully tap out the rubber cylinder and the plastic internal piece behind it.
Insert the plastic piece in either of two ways. Pointy part Out (for Schrader) or just a round opening Out (for Presta). Rotate the rubber piece correspondingly to show the large opening for Schrader or the smaller opening for Presta and place it inside the valve over the plastic piece. Screw the knurled barrel on tightly.
Aug 12, 2010 | Zefal Bicycle HPX 3 Road Frame Pump
How do I change to presta
If your pump is not double sided (which the one in the picture looks like) the rubber valve can be reversed very easily by unscrewing the outer cap where you usually insert the valve and turning the little rubber valve around before screwing the outer cap back on.
Jun 10, 2010 | Zefal Bicycle Air Profil Road Frame Pump
Unrepairable inner tube
True Goo inner tube sealant! Go to a bicycle repair shop with your stroller, and honestly, have all the tires shot up with this goo and then pumped up to your desired firmness...
I have a different jogging stroller, but I know the Maxi Cosi's Mura has the same air pump access as other bicycle tires like my jogger does. I kept getting flats, and this goo has kept my tires firm for 6 years now, I used to have to bring along a pump, but never again after this repair, it plugged up a small leak for one of my tires that kept going flat quickly and keeps the others from the eventual softness that was recurring.
Aug 23, 2009 | Maxi-Cosi Baby Gear
Zefal Bicycle Air 1 Floor Pump Logo
208 people viewed this question
Top Zefal Cycling Experts
John Egan
John Egan
Are you a Zefal Cycling Expert? Answer questions, earn points and help others
