Question about Garmin StreetPilot 2730 GPS Receiver
My touch screen won't work
I cannot use my finger to get directions or change the music, without using the remote control. What am I doing wrong. I just changed the speaker cable, too.
  • 3 more comments
  • Anonymous Jun 28, 2008
    Touch screen is dying around the edges
  • gijan Jul 24, 2008
    It turns on and the buttons function, but the touchscreen does not function. Unplugged cleaned touchscrren with dry cloth. no affect.
  • Anonymous Jul 26, 2008
    Same problem
  • mkern002 Dec 28, 2008
    Same problem but intermittent. Just today, both the touchscreen and the remote quit so I can't operate. Both were working fine until I got a message "37 mph speed warning ahead" ( or something to that effect ) I presume from XM Navtraffic which I have activated. Now the unit is not operable and, incidentally, there was not speed issue despite multiple such messages. On the road now and forgot my AC power cord to can't download an update. Will need to wait until home in about a week or so. Will email Garmin support.
  • Anonymous Apr 02, 2009
    My screen is shifted along the bottom, so I have to press to the left of the target area. Calibration fails every time. Of course I cannot go left of the 'back' area so the unit is useless... without a remote, which works fine. Georgia Power bought a ton of these and all fail within 2 years...
  • 22 Answers
My 2730 would not calibrate. I saw this on a forum and it worked like a charm.
1) Fill a bowl or sink with warm water and a small amount of neutral soap. AJAX worked for me!!!!
2) Turn the SP2xxx screen down towards the water and immerse the front of the unit in the water.
3) Using a *soft* toothbrush, *gently* clean around the frame edges of the screen. With care, the soft bristles should dislodge any foreign object that may have become lodged between the screen and the unit case.
4) Rinse the front of the unit under running water.
5) Gently dry the outside of the unit with a soft towel or cloth.
6) If desired, leave the unit in a warm airing cupboard overnight to completely dry out.
Hook up the unit and try it out! All reports I've read elsewhere reported that the touch screen worked again after this process. If it fails, you were going to send it back to Garmin anyway so you haven't lost anything by trying it. This worked and I plugged it in right after with hair drying on cool for a couple minutes.
Posted on Aug 19, 2009
How do you get the menu/factory display off TV screen to get tv to work?
To exit the factory mode, you should have its remote control. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Without its remote control, no other way. Contact the authorized service center.
http://electrohelponline.blogspot.com/
Jul 25, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tip
How to block explicit songs to an iPod
<p>Apple iPod touch is a portable music player with touch screen. It connects to the Internet via Wi-Fi, allowing you to browse the iTunes Store for music, some research explicit lyrics, and then downloaded directly to your device. If you are the parent of a child an iPod Touch, the device can block the download of music with explicit lyrics. To define a restriction of access and change settings. Only the person who knows the password can block explicit lyrics. <br /> <p><br /> <p>1. Press the "Home" button below the screen of the iPod Touch. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen. <br /> <p><br /> <p>3. Tap General. <br /> <p><br /> <p>4. Tap "Restrictions." <br /> <p><br /> <p>5. Tap "Turn restrictions." <br /> <p><br /> <p>6. Enter a four-digit password, and then retype it to confirm the prompt. "Limitations" is displayed. <br /> <p><br /> <p>7. Touch the screen and drag your finger to slide up on the "Limits" screen until you click the 'Authorized Content. " <br /> <p><br /> <p>8. Tap "Music and Podcasts," then the "Explicit" click "Off". <br /> <p><br /> <p>9. Press the "Home" to return home from the screen of the iPod Touch. <br />
on Aug 05, 2011 | Computers & Internet
Hello, My touch screen not function, but all switch work normal.When need touch screen to change something hi not work. the display work good .
Have you tried touching the screen with a pen, or stylus. Or even your finger nail? My KORG does not work well with fingertips, needs something harder.
Apr 01, 2014 | Korg Pa800 Synthesizer
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
Low battery icon on, won't recharge
Hi. If you do some research, you will find that this is a common issue with the Harmony One remote. I suggest using an elastic band to hold the remote firm onto the charger. That works for me.
Aug 03, 2011 | Logitech Harmony One Advanced Universal...
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
All of a sudden my "Touch screen" does not work!
My older garmin came with a remote and my touch screen went bad. So in order for me to use it at all, I have to use the remote control.
Aug 02, 2009 | Garmin Nuvi 660 GPS Receiver
Remote control touch screen is not working
Flip ipen the front face of the remote control so that you have access to the buttons underneath. Press and hold the "light" button on the outside right of the remote while pressing the "enter" button to the right of the number "1" button.
THIS WON'T WORK IF YOU HIT THE "enter" BUTTON BETWEEN THE ARROW KEYS.
The screen should now flash PRESS and VCR 2 - press the onscreen key marked VCR 3.
The screen should now flash PRESS aqnd OSD - press the onscreen key marked OSD.
Test all of the onscreen keys. If you find them still unaligned, repeat the process.
Feb 24, 2009 | Nakamichi SoundSpace 12 System
Remote control problem
Yeah, At first i had the same problem. I reset the iPod by pressing and holding the MENU button and the CENTER button. This seemed 2 fix it 4 me.
Jul 22, 2008 | Bose SoundDock Digital Music System for...
Garmin StreetPilot 2730 GPS Receiver Logo
311 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
