Question about GE Microwave Ovens
We have a JNM1851DBB GE Microware oven. The microwave is not generating any heat and the motor sound is much louder than normal.
    Brigadier General:
  • 8,909 Answers
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Nov 12, 2010
Microwave runs but doe not heat
follow this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 26, 2013 | GE JVM1190 Microwave Oven
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
G.E. spacemaker microwave stopped heating,made louder than normal sound,smelled odd.
The magnetron has failed, "heats food" to repair the unit will approach the cost of a new microwave oven.
May 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The keypad works; the microwave can be turned on and turntable turns round, the light is on, the motor sounds (a little louder than normal) but no heat can be generated. What could be causing this?
No heat would mean the magnetron circuit has failed. It's the part that generates the microwaves that heat the food. If it is making a loud buzzing noise, it could mean that the magnetron or the high voltage diode has failed. Since there exists high voltages inside the oven, would require a qualified service person to repair. However, if the magnetron has failed, would recommend buying a new oven since the parts alone can cost as much as a new oven.
Dec 06, 2010 | Microwave Ovens
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Motor sounds louder than normal. food won't heat up.
This sound like the Magnatron (this warms the food) has gone out and needs replaced! To be honest with you ,unless you can do this repair yourself it might be cheaper to buy a new oven
I hope I was of help!
(Please rate! This is what keeps this site free!)
Dec 14, 2008 | Sharp R-23GT Microwave Oven
GE Spacemaker Microwave, Model J VM1650AB5 Not heating food
If you sure that lauder sound comes from turntable motor than it needs to be replace.
Nov 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The light inside the microware
1 take the front grill off. 2. you will see a cover with one screw around the area of the light. normally this is right in front.
May 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE MICROWARE WON,T HEAT UP
Likely problem: Blown magnetron. On microwaves, this can generally go dead, usually with a popping sound. Solution: A: Call an appliance repairman to replace the magnetron in the device, or B: buy a new microwave. Depending on how much you paid for it, you might be getting a better deal on either end.
Jun 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
