Question about Waring MBB518SS Professional Work Top Blender
The blender will not turn on. I flip the switch and nothing happens.
Blender appears to be stuck on high. Today we changed the variable speed button blender still appears to be stuck on high.
The speed control usually is by electronics. The speed control switch will merely be telling the circuitry what speed is required but if the circuitry is faulty nothing will happen.
May 13, 2016 | Vitamix 5200 VariableSpeed Blender
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
My blender died last night. I flipped the switch and the blade did not move. It was trying....but eventually stopped trying. Now nothing happens when I flip the switch. I have been using it daily for over...
:( my condolences to the blender family.Unplug it its life support and accept your loss. Gently wrap the cord around it and lay its body softly in the trash can. At least you know it tried to the very end. As you walk the isles of walmart, I feel you will find another to take its place.Good luck.
Jul 08, 2009 | Oster 4124 Beehive Work Top Blender
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Wont turn on. its plugged in and the switch on the plug socket is turned on
have you fix the container? most blender today has a switch to verify if the blender container is fixed to the motor.
May 31, 2009 | Blenders
Power flashes but doesnt start
Yes, I know what it is. On the base of the blender jar (the plastic base) there are some "fingers" that must contact the base to allow operation to take place. Turn it upside down and look at the little plastic "fingers" around the outside periphery of the plastic base.
These fingers tend to break over time... mine only has two left right now, and it only works in one particular position as a result.
Rotate the blender jar one spot at a time until you are able to operate it "normally". I use it for margaritas, and it won't allow me to push the button for Frozen Drink unless the jar is in the right position.
I am going to try and find a replacement base (or entire blender jar) somewhere... or else I will finally have to retire my favorite blender of all time!
Dec 20, 2008 | Oster 6700 Work Top Blender
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Waring MBB518SS Professional Work Top Blender Logo
63 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
