Question about Kenmore 659 Electric Dryer
Have a kenmore 80 series model 66812690 put in anew heating element still will not heat
muttandjeff
  • 359 Answers
SOURCE: whats the price for heating element kenmore 80 series
call sears parts line they are about the same as everywhere else
Posted on Dec 09, 2008
SOURCE: kenmore 80 series runs but dont blow hot air
I had the same problem. The heating element is most likely broken. It is an easy fix and costs about $75-$100
Posted on Dec 12, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
freetek
  • 5568 Answers
SOURCE: My kenmore 80 series dryer
This seems to be an electric dryer so, no pilot light.
The heating element might have failed or it has a heavy current fuse that has failed.
There aren't many things that a dedicated DIYer can't do given time, a few common tools and some common sense.
Having a multimeter at home helps too; these can be had at electronics or auto parts stores and usable instruments can be had for <$20 US. Somewhat intelligible Chinglish instruction sheet is included.
Posted on Jan 09, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Where is the thermal fuse on a series 80 kenmore electric dryer. will this act as though the power is off? How can i test the fuse?
Yes, but there are several thermal limiters, they should reset when the unit cools, so likely that is not what is happening.... Forcefully turn the breaker FULLY off, and then back on, and test again...
The thermal limiters are located along the air flow path, typically downstream of your burner, the purpose is to prevent overheating and fire. These limiters stop the HEATING element and not the drum motor...
Feb 27, 2011 | Kenmore 63942 Dryer
Dryer rotates, but there is zero heat. Kenmore Series 80, model 0104806
First check your breakers in the power box to the house. If one the the legs is tripped, the cylinder will turn but will not heat. Next, check the thermostat switches near the heating element for continuity. If no continuity, replace them. Check heating element for continuity. If no continuity, replace.
Aug 08, 2010 | Kenmore 84052 Dryer
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Kenmore 80 series get very low heat
some of the 80 have two part element . one is burned out . or loke for a bad thermo. / hope this helps .
Nov 24, 2009 | Washing Machines
No heat in kenmore series 80, model 85040
hello there:
here is some troubleshooting ideas for you to help
A dryer sometimes won't heat or heats too slowly because of a variety of reasons. By following the guidelines below, you can inspect the heating elements on a gas or electric dryer to pinpoint the source of the problem.
Electric heating elements, found in electric dryers, are self-contained units located in the back of the dryer. A defective heating element is frequently the source of no-heat or drying problems. Remove the back service panel to gain access to the elements.
The heating elements are located inside the heater ducts. If you think a heating element is faulty
Oct 26, 2009 | Kenmore Dryers
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
Jun 14, 2008 | Kenmore 63942 Dryer
Kenmore 659 Electric Dryer Logo
159 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
