Question about Kenmore Toaster Ovens
Hi , Gas range Kenmore #790.75658001.Self clean cycle does not work. Locked the oven door and error cod on the screen F-3 and I can not anlock the oven door . Please can you help me.
  • 4,323 Answers
Hi
Error F3 appears when there is something wrong with the keypad or the Electronic range control (ERC). Check that the keypad is firmly connected with the control board, then press Cancel, if error appears then you'll need to check the ERC. To resolve this issue disconnect the power to the range. Now gain access to the back of the clock (electronic range control or ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide. Make sure that the cable is not cut and nothing is shorted on the keypad. Turn power back on to range and observe. If the error is still there then you would need to replace the board. Hope this helps...
Daniel
Posted on Nov 12, 2010
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Oven thermostat quit working
Yes you can. I am in the process of showing someone else how I rebuilt mine here: http://www.fixya.com/support/t8640984-fix_fan_in_hamilton_beach_31197c and waiting for some images from him to continue. The thermo on these units never worked properly anyway as they used a metal plate "sensor" with some heatsink compound on it simply screwed to the top right corner next to the top of the glass door. Worst (but cheapest) way to design this thing. They are all inaccurate and they are STILL using this design on their current models. ALL the parts on this oven are spec orders from Chinese manufacturers. I found several companies that make these (motors, thermos, switches, elements, etc.) in China and they usually want a minimum order of 5000 or so although a few will sell just 500. The cost for the convection motor for example is $1 if you buy 50,000 or more! As for just the thermo, there are several ways to get one cheap (a regular oven thermo costs from $80 to over $200) but you have to shop around. I got a box of 12 old, but still brand new oven/range thermos from a surplus supply place in Texas. I paid $80 for the box (list for each was $143) and sold 10 of them on eBay for 19.95 each. I kept one as a spare and put the other one in the toaster oven. As it does not matter what brand you get, it makes things easier to find. The motor can be a real pain however. Just go around to appliance rebuilders in your area (if you are in a major city) and they will have boxes of parts they have scavenged from all kinds of appliances. The thermo in the HB is very tiny so your only concern is to find one that will fit. The open space is a little smaller than 3"x2". The thermos I got were 3 1/2" tall so I had to modify the orange power light above. It was melted anyway though still working. Make sure you get the thermo for an electric full size range with 3 terminals, at least a 1500 watt rating per terminal (15 A minimum at 120V) and a 42"+ cap tube with a sensor tube of 12" length or less. They will have electric thermos with 2 terminals that are small, BUT they are for GAS ranges and wil NOT handle the current you need. I will be posting images of all my repairs on this at the URL above once I get some images back and have the time to respond.
Jun 22, 2012 | Hamilton Beach 31197 120 Watts Toaster...
Amana self clean oven has the locke on with the door open I can't take the lock off tu close the oven
Hi there.
Check the door interlock switch, contacts may be bad and needs replacement.
Regards.
Aug 03, 2011 | Toaster Ovens
The interior of my euro-pro kitchen rotisserie convection oven model TO241R needs major soot and grease cleaning. Is there a way to clean it on high temperature setting? If not, please recommend a...
Most toaster ovens don't have a self clean function, because they are not made of the same sturdy metal that full ovens are made of. Clorox Clean-Up works pretty well if you spray it on the grime and let it sit for 5-10 minutes before wiping it away. Let it sit longer for tougher dirt.
May 03, 2011 | Toaster Ovens
Door does not close
After 3 years of perfect service, our toaster oven's door stop closing easily. After reading the internet and trying to contact Cuisinart for a solution I was stumped and frustrated. Someone on the internet mentioned using wd-40, but I didn't want the smell when I toasted! I try cleaning the metal arm that held the glass door using an alcohol pad and that actually helped a little! After thinking about something to lubricate the door are with that won't smell awful and hopefully won't catch fire -- I decided to try olive oil! I took a little, very little on a paper towel and rubbed the metal arm a few times -- It worked!!!!!!! The Door now closes with the greatest of ease! and doesn't smell awful when you toast, so far it has not caught fire. Give it a try! I love to give it 4 starts, but Cuisinart support didn't have a solution... I'm sure even if I suggest to them my fix that won't share the info, but use at your risk! I am certainly not responsible for any mishaps that may occur if try my fix, but worked for me.
Dec 31, 2010 | Cuisinart TOB-50 Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Main problem, bottom two elements have conked out. Where do I get new ones? Next, how clean glass door when it won't come out of slots? Next, what do I use to clean shploops patina off crumb tray?
    you can get the new elements from the online sites mentioned below www.repairclinic.com also from www.partsselect.com and for cleaning follow this instructions
    1. 1)take out a bowl and in that bowl make a paste using the baking soda and vinegar
      2)After making a paste open the oven door with the oven off. Take the sponge dipping it into the paste of vinegar and baking soda.
    2. 3) After dipping it into the paste. Smear it on your oven door. Leave on for about 10-15 minutes longer for more stubborn stains. Now the time is up! take that sponge rinsing it in water and wipe down. Little or no elbow grease is required. Now you have a beautiful oven door.
      This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya.
    Mar 04, 2010 | Bella Cucina 13049 1500 Watts Toaster Oven...
    Need to activater self-clean
    Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
    1. Set the Start time for the time you want the cleaning to begin.
    2. Set the Stop time to a time 2-3 hours after the start time.
    3. Close and latch the oven door.
    4. Set the selector switch and/or thermostat to "Clean."
    Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
    Farberware convection broil oven modle T-4850
    I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
    1-888-464-0797.
    Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
    Parts for europro model to289
    I HAVE A FAN THAT WORKS.WILL SEND IT C.O.D. IF YOU WANT IT JUST PAY THE POSTAGE.
    May 25, 2008 | Euro-Pro EuroPro 6Slice Toaster Oven with...
    Toaster Ovens Logo
    65 people viewed this question
    Top Kenmore Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Kenmore Toaster Oven Expert? Answer questions, earn points and help others
