LG Monitor L194WT - Indicator Lights Flashing
Today when I return to my computer when monitor has been in SLEEP mode, the power indicator light is flashing blue, at two different speeds. After I wiggle the mouse and hit keyboard keys it comes back to life. It comes back as a black screen with FLATRON WIDE, then the actual image appears with the word ANALOG in the upper right.
I cannot find the flashing light problem in the online user manual on the LG site.
Just concerned that it's on its way to crashing....
Any ideas? And thanks
  • cp556 Jun 19, 2008
    Now second day of problem. Monitor on-off switch doesn't appear to be working, and screen only comes back to life when I hard boot the computer.
    Thanks.
    Update:
    When monitor goes to sleep, the power lights flash oddly ... purple and blue, in two different rhythms. At that time, monitor's on/off switch doesn't respond. (On/off switch DOES respond when monitor is working (solid blue light) or in power save (yellow light). When lights are flashing, monitor also does not come back on when mouse is wiggled and keys hit.
    If I attempt a hard boot (did it just once) the monitor came back.
    So, is this problem the monitor or the computer??
    Sorry to be so dense....but thanks.......
  • 1,879 Answers
Hi n hello
tried restarting the computer ?
Posted on Jun 19, 2008
  • 2 more comments
  • monk3ybidzness
    monk3ybidzness Jun 19, 2008
    seems that when your computer goes to sleep and then back - at wake time the monitor isn't getting the signal.
  • monk3ybidzness
    set your power options like these and just use a BLANK SCREEN for your screen saver
  • monk3ybidzness
    Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
  • monk3ybidzness
    Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
    check your warranty with that monitor and exercise it.
How do i fix a monitor that sometimes just turn off by itself and turn on after being cut of the elec. power?
There are settings for the sleep (power saving) modes that came with Windows updates.
Some of our monitors also shut off the power indicator light when they go to sleep.
Solution: Check the power saving settings in Windows.
Jul 22, 2015 | Computers & Internet
My Acer monitor sleeps on red instead of amber. Is this a problem?
Different monitors have different indicator lights. If you do not expereince any problems with the monitor then it is ok
Aug 10, 2008 | Tiny Computers B1996 19" CRT Monitor
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
My L194WT -SF WONT WORK NO POWER USED SAME POWER LEAD ON DIFFERENT MONITOR NO PROBLEM
Hello Steve,
The most common problem with the L194WT monitors is a failure of the power supply board. There are parts called capacitors that fail and can cause the issue you have. Sometimes the power light will just flash, sometimes it takes several minutes to display a picture or even a wavy picture, all of these issues indicate a failing power supply board. These boards can be repaired if you can do a little soldering. The L194WT uses the same power board as the L196WTQ and we have a step by step repair guide with dis-assembly instructions available at http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/ Look over the guide and check your board to see if your capacitors have bulged and need to be replaced.
I hope this helps, if so please rate our solution.
BuddyMc
Aug 07, 2011 | LG L194WT 19" LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
LG flatron L1917S problem
dear
as you said the problem is in your monitor.plz checked it from a qualified professional.
Apr 01, 2008 | Computers & Internet
Computers & Internet Logo
752 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
