Question about Husqvarna 28cc Hand Held Blower HVH 125B
Husqvarna will not start.Less than 1 year old and the spark plug is corroded. Change spark plug and still will not start.
  • 1,040 Answers
Here is a Link to one of my Tips:
http://www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Nov 13, 2010
  • Jim Parker
    Jim Parker Nov 13, 2010
    Sorry, but you will have to get rid of the ( http:// ) in order for the Link to work.
    Jim
What causes hard starting
Dirty plug...
Typically lack of use.... (2 or 4 cycle?)
Stale/dirty carb or gasoline, poor carb/choke settings...
Tired ignition coil, corroded connections
leaky fuel hose.. lousy compression, worn cylinders and clogged exhaust muffler...
(see ... didn't even mention "points" or "electronic ignition")...
Short story... Everything...!!
Sep 21, 2016 | Garden
1983 Capri RS WONT START it is getting spark to the plugs and fuel turns over fine just wont start
Points or electronic ignition? Corroborator, or fuel injection? Was the car sitting idol for a long period of time, say, 6 months to more than 1 year? With a car that old, I would start with replacing spark plug and ignition wiring. Have you checked the spark plugs? Make sure they're cleaned and gaped. If corroded, replace them.
Sep 22, 2014 | Cars & Trucks
How to change the spark plug on a Husqvarna 6021P 21 inch
I use a spark plug wrench or a deep socket and turn counter clockwise.
Jun 16, 2014 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
My model TB46599, less than 1 year old, has no
Absolutely. What sometimes happens is that carbon will build up on the cylinder head. Then when you try and start it you get a mini backfire and it knocks the carbon loose. The carbon get mashed under one of the valves and then you end up with no compression.
Here are a couple of things you can do to try and loosen it up. (Mind you that you will have to change oil after this and probably need a new spark plug.)
1. In a well ventilated area... preferrably outside and off the grass or any vegitation area, remove the spark plug and turn the engine until the piston is all the way to the top. (TURN OFF THE FUEL SELECTOR)
2. Then dump about 3 cap fulls of oit into the cylinder head via spark plug hole. (Cap from 1 qt small mouth oil bottle)
3. Pull starter cord slowly 2 times.
4. Fill the cylinder all the way to the top of the cylinder head / spark plug hole. Keep it full for about 10 minutes. Add more gas if you have to. The goal here is to soak the overhead valve seat with raw gas for a bit.
5. After 10 minutes... YANK the starter cord with ign off knowing full well your going to make a mess.
6. Add Fresh gas to cyl head (not full this time) and YANK the cord again.
7. Keep pulling cord until vapor / gas cloud stops exiting spark plug hole.
8. Install spark plug and check compression.
Good compression... Good deal.. CHANGE THE OIL because it leaked past the pistions rings during the soaking process.
Still no compression the head will have to be removed and the vavle seats hand lapped with grinding compound.
NOTE: Before turning on the ignition switch... and attempting an engine start make sure that the unit is not soaked in gas i.e do a good clean up job.
Safety First!
Thanks for using FixYa.
Kelly
Apr 02, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Chain saw no start
It needs spark, fuel and compression to run, which is missing?
Lets start with spark. Replace the plug (very inexpensive and great insurance), then do this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Before we get to fuel please download and follow the start procedure in your Operator's Manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I own a Husky 359 that 1 time I forgot to set the fast idle (close then open choke). It was near impossible to start. I have missed the initial attempt to fire and flooded it too, again almost impossible to start.
If it has spark and the start procedure fails, put a teaspoon of fuel mix in the carburetor throat, open the choke, and pull. Does it fire and attempt to start? Yes it probably has a fuel delivery problem. Please repost with what you did and we will continue. HTH
Lou
IMO regardless of what your manual says ( yours probably 50:1) all 2-cycle engines should be operated on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle engine oil). Once adjusted for this mix they start easier, pollute a bunch less, and do not foul out plugs, cylinders, or mufflers. Run lean conditions are most often caused by dirty air filters, air leaks not detected by the operator, or failing to add any oil to the fuel in the tank. Using a 32:1 mix prevents none of these occurring! I use a Pioneer chainsaw I purchased new early 1980 with a 50:1 mix.
Jan 06, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain saw works great until its shut off then it wont start again
A couple of suggestions:
How old is the gas in the tank? If it has sat for a year in the tank or the can, the gas won't burn as easily because of octane breakdown. Mix in newly bought gas (with oil of course).
Pull the spark plug(s) and check the spark gap referring to your manual. If the gap is too wide, you'll have a hard time starting it.
It's also a good idea to check how dirty your spark plugs are, and clean if necessary.
Depending on the age of the saw, if it's 35 years old or more, you may have to put less 2-cycle oil into your mix. The ratio has changed for all 2 cycle engines if they're approximately 35 years or older. Instead of 30 to 1 it's now 50 to 1.
Sep 21, 2009 | Garden
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
Car wont start
I can only say that for the old cars even sitting for a year is not healthy, because most parts of engine, starting system, charging system will get corroded/deposited. Most probably you will need to change battery, motor oil, fuel, spark plugs, check the starter and alternator. Also check the fuel pump, fuel filter. First shot would be battery, fuel, spark plugs and starter.
Good Luck
Feb 20, 2009 | 1999 Ford Taurus
Husqvarna 28cc Hand Held Blower HVH 125B Logo
920 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
