Question about Gaggia Titanium Espresso Machine
Stema Knob wont fully stop flow of steam/water
When making a shot of espresso water comes out steam wand as well reducing the size of the espresso shot.  Additionally when texturing milk the steam still leaks when knob turned off.  Its like the knob hits a stop but the valve its connected to hasnt fully closed.  Any ideas on how to fix?  Thanks Julian - Australia
  • Anonymous Mar 29, 2014
    leaking water from steam wand
    Sergeant:
  • Gaggia Expert
  • 223 Answers
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Posted on Jun 19, 2008
I have a Francis Francis x1 machine, but when i want to make an espresso shot, and turns on the espresso button, the steamer spour out boiling water (not steam, and not while turned on). Does anyone k
Don't know how your controls are set, but you have two switches on the front and a knob on the right. The switch for the steamer (the right hand switch) should be off. The knob on the right should be turned clockwise to turn in off. Then no water or steam should come out of the steamer wand. If it does, the seal on the knob inside the machine is broken. It can be repaired but only if you're handy with a screwdriver (make sure if you take it apart you disconnect it from the mains).
Jun 24, 2014 | FrancisFrancis! Coffee Makers & Espresso...
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
Machine is a incanto typ sup 021ydr.
Check the tip of the steam wand make sure it is not blocked. If not then press in on the steam knob after opening, if that works then the steam valve assembly needs to be replaced.
Jul 12, 2009 | Saeco Incanto Classic Espresso Machine
Starbucks Sirena. lights blink, won't heat.
johnshami had this solution on another post, and it worked for us:
  1. make sure the water in the tank is stone cold -- which is a no brainer since it will not heat h2o unless it's primed.
  2. take off steamer wand cover, turn the steamer knob clockwise till pump starts.
  3. then s*ck (as you would on a straw, with your lips sealed around the end of the steamer wand) the tip of the end of the metal tip hard until pump stops
  4. may need to do it a couple of times. yes this seems crazy, but it works! you are flushing out the vapor lock in the pump.
Jun 10, 2009 | Saeco Starbucks Sirena Espresso Machine
Water leaking from steam wand when brewing shots
Try this from another post. It should help.
The steam wand began to seriously leak but a call to Starbucks Customer Service line and I was talked through how to adjust it so that the leaking stopped. It requires taking off the top/back panel of the machine (6 philips screws) then using a small allen key (1.5 mm I believe) to loosen and adjust a plastic oblong donut-shaped thing (a "cam" actually) on the shaft of the steam knob... no more drips.
The key to prevent dripping is to open the steam knob without putting pressure on it when it gets to the full-open stop position. Cranking it too hard when it comes to a stop in the full-open position will slowly move the cam out of position. Then the shaft doesn't fully seat inside the machine anymore and won't fully shut off the water to the steam wand. Then, no matter how hard you crank the knob in the shut-off position it will still drip. The purpose of the cam is to stop the knob from complete unscrewing and it also turns the pump on and off for the steam wand. The cam adjustment is very small but completely solves the dripping problem. Seeing inside the machine made me realize how easy it would be to repair problems as long as I can get the parts from Starbucks or perhaps Saeco.
Dec 21, 2008 | Starbucks Saeco Italia Digital Barista...
After descaling stuck in infinite loop
How old are your machine?
How often do you descale the machine?
I think it can be the flowmeter in the machine that needs to be replaced.
Try to descale the machine to see if it help.
Best regards
/Mirran
Sep 07, 2008 | Saeco Caffe Charisma Espresso Machine
Coffee tastes burnt/No steam for froth
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
Starbucks Athena
I have had this machine for four years now, and it is FAB!!! it does have an extra step to it- after you put in coffee and add water to the reservoir, you DO need to prime the pump. So here's what you have to do:
-Fill the reservoir with MORE water then you think you will need, fill the coffee filter with the standard amount of finely ground bean.
-Turn the machine to "on," making sure the "steam" switch and valve (knob) are off.
-Wait till the green "ready" light comes on, then put an empty cup under the steam wand and turn the valve on (the steam switch is still in the off position). Hot water will come out of the steam wand, allow it to flow until the "ready" light blinks off. Discard this.
-close the steam valve, stopping the flow of water.
-turn the "steam" switch into the on position, wait for ready light to come on again.
-put your milk container under the steam wand and froth to your heart's content (this machine makes GREAT frothed milk and you should use a large enough milk container to allow for that! *smile*)
-when you have finished with the frothing, close the valve and flick the "steam" switch back into the off position. You are now ready to make your espresso.
-push either of the two buttons, ie one or two cups, and the espresso will start to flow. There is a way to set the length of time for each of the two buttons, but I have had mine set perfectly for so long i don't know how to do it any more. Sorry!
This has been the best machine I've ever used, and has lasted me for years. I heartily recommend it!
Jan 02, 2008 | Estro Barista Athena
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
230 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
