Question about Brother IntelliFAX 565 Plain Paper Film Fax
Fax received but no message printed brother home fax v3 please advise thanks Peter George
  • plgeorge Nov 13, 2010
    Yes Paper was loaded the wrong way
    Thanks
    Peter George
  • 2,382 Answers
Hi, If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward (make sure the faxes they send are face down in the feeder, if you can read what you are sending they will be sent blank). You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its "copy" function, or print an activity report. If all is well on your end, the problem must be with the sender's machine.
If, by any chance, you're using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that's the case the heads won't print on the side that isn't heat-sensitive.
It may be a cartridge problem but more likley a laser problem which will require a service engineer.
Posted on Nov 12, 2010
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Looking for a manual for Brother Home Fax V3
Well you may please follow the link below, follow the page and provide all the model information to download your Fax machine manual -
http://www.brother-usa.com/manuals/default.aspx?PGID=2
Good Luck!!
Thanks for suing FixYa!!
Aug 28, 2010 | Office Equipment & Supplies
Unable to print when the machine was receiving the fax, phone call rang then it stoped to receive the fax and I got a message "unable to print" I checked everything by user's guide but couldn't fix. Please...
OK ill help you A faxmachine has a buffer on it what it does is fasimilate the data into a text or message that can be printed what happens here is you have fax/printer the buffer for the printer should be on your computer and not be sent until your ready to print (also known as the print que) all print jobs should be saved when a fax comes in but when a fax comes in and you dont have print que software your printjob is lost. But this brand is familiar to me so the software you install for this hardware should have a print que or buffer so you dont have this problem maybe you need the new BROTHER MFC software at the following link http://www.pronto.com/user/search.do?displayQuery=brother%20mfc%2Fsoftware&SEM=true&query=brother%20mfc%2Fsoftware&adid=1196541613-6635448d-0_mes&ref=brother%20mfc%20software&creativeid={creative}&site={placement}&loadingComplete=true
Oct 19, 2009 | Brother MFC-640CW All-In-One InkJet...
Fax machine to one user gets missing pages.
Its a fluke. Messing with your fax parameters can really screw things up. I don't advise it.
Sep 30, 2009 | Brother FAX-8360P Plain Paper Laser
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Reg. printing of memory received messages
Yes, after refilling the cartridge, fax in memory automatically print out with charms. :) thanks for your help.
Aug 18, 2008 | Office Equipment & Supplies
Unable to receive fax
unable to send fax through power line carrier communication. only some part of the document received
Apr 28, 2008 | Brother IntelliFAX 560 Plain Paper Fax
HP fax 1010 - receives on LCD but never prints fax
Can you receive from other numbers? Can you brother xmit to other numbers? Can you xmit to him?
Feb 02, 2007 | HP 1010 Plain Paper Inkjet Fax
Brother IntelliFAX 565 Plain Paper Film Fax Logo
147 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
