Question about Roper Washing Machines
I have a Roper RTW4400SQ0 that will not agitate or spin. It fills with water but does nothing else. It makes no sounds.
  • 221 Answers
SOURCE: Admiral washer won't agitate,drain, or spins
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Posted on Jan 08, 2009
rylee_smith
  • 8619 Answers
SOURCE: Roper top loading washer not spinning or agitating
Hi
  • The motor coupler may be broken. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The transmission may not be shifting properly. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
If your washer doesn't agitate, check these:
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 20722990 series won't spin or agitate
This is a direct drive washer that uses a motor coupling. It sounds like your coupling is broken. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
If this is not correct, please post back with your make and model number.
Posted on May 11, 2009
  • 72 Answers
SOURCE: Roper top load washing machine. Fills with water and then stops
Check out the drain pump, it is not uncommon stuff gets stuck in the impeller preventing it to do its work.
Also check out the drain filter and that the drain tube is not clogged. Very common causes of trouble in my experience and would give symptoms like you describe..
A good method to check if the output side is clear may seem a little gross but... take a deep breath and blow through the drain tube from the other end (taking whatever precautions you feel like).... It should be possible and if you can't, you know where the problem is.
Posted on May 21, 2009
dwrooker
  • 6 Answers
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Posted on Oct 06, 2009
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 10, 2011 | Roper RAS8445KQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Oct 04, 2009 | Roper RAX7244KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Model RAS7133pqo
If it agitates, you probably need a new gearcase. If not, check the coupling between the gearcase and motor. Hope this helps!
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Machine won't agitate or spin.
Its possible that the agitator that turns back and forth, to clean your clothes, is warn-out. I had the same problem with mine. If your agitator has a fabric softener piece on top of it, there should be a plastic circular clip, that you have to lift up, that removes the fabric softener piece. Once you remove that, there is a plastic cap, that covers the bolt, that secures the agitator, to the drum. After you remove the cap, you will see 4 plastic hooks, that grab to the inside lining teeth, of the agitator. If the 4 hooks are worn out or the teeth are worn out, then this is your problem of why it won't spin nor agitate. I put 2 small screws, one on each side of the clips, so that the clips stayed out, against the teeth, so that at least it would work, until you can replace the agitator. I hope this works for you.
Jan 19, 2009 | Roper Washing Machines
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
