Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Ice build up in freezer compartment - Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Nov 13, 2010
The fridge has stoped workingbut the freezer is fine
if it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
May 14, 2017 | Bosch KGU6655
Freezer compartment of my fridge ices up quickly
Check seals around door....you need to reduce the amount of moisture entering the freezer compartment.
The frost will build up on anything in there.
Sep 01, 2009 | Refrigerators
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box.  The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals.  There is of course, there is a possibility that the defrost cycle on the unit is not working.  About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts.  If this is not happening, your defrost timer or the coil it heats could be bad.
Nov 12, 2008 | Refrigerators
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Ice build-up in freezer - Kenmore Model C978-66795-2
don't know this appliance but for guidence:
some appliances have the evaporator in a compartment at the top of the freezer and the drain comes out of the back and runs externally to the drip tray. there should be a grill in the compartment so just peer into it and see if there is ice build up.
wherabouts is the freezer ice forming?
Sep 04, 2008 | Refrigerators
Drain plugged in freezer
First of all, is it ice or frost? If it is ice, I would say you have a leaky water valve to icemaker, running down evap. coils. Replace water valve. If you have frost-find out why it is not defrosting(defrost heater, defrost thermostat, or defrost timer.
Jan 17, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
