Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Have iMac ejected hard drive so I could remove now computer won't recognise the hard drive
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,099 Answers
First thing I would do if the drive is connected via a usb hub connect it directly to the imac, then if that does not work try one of the other usb ports. If that does not work connect it to a usb port you know works and then go into the applications folder and then into the utilities forlder and open up disk utility. Once opened your hard drive should appear in the left hand box click on your external hard drive then go to the first aid panel and run verify disk and if any problems appear run repair disk. Hope this helps.
Posted on Nov 12, 2010
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
CD stuck in imac
Have you tried holding the mouse or trackpad button down immediately after powering on. This forces the CD drive to eject during boot up.
See this page for all sorts of useful Mac tips.
http://www.danrodney.com/mac/
Aug 24, 2012 | Apple iMac Z0GF0005F Desktop
I want to eject cd from cd rom apple system imac
To eject a CD/DVD that is not recognized by your computer, boot up while holding down the eject button on your keyboard, and continue to hold down eject until the disk ejects.
If this does not work, hold down your mouse button while booting up in the same way.
If neither of these work, open Terminal and type in the following:
drutil tray eject
If your disc does still not eject, your optical drive likely needs repair.
May 21, 2010 | Apple iMac G5 Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
IMac disk drive ejects audio cds
1) Restart the computer and try again. If that fails, 2) Gently blow canned air into your CD drive slot. If that fails, 3) Bring the unit in for a drive replacement.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Accidental ejection
try turning the external drive off & wait a minute then turn it back on.if it works just drag what you want to transfer from your mac to the external drive and it should copy it to the drive.
Apr 06, 2008 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
85 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
