Question about Espressione Caff? Novecento
I have a Caffe Novocento that is leaking from the steam nozzle when brewing espresso.
  • prof_rafi Nov 18, 2010
    I have scrupulously followed your instructions of cleaning and descaling the machine but it continuously leaks when in brewing mode , in fact a stream and not just a leak. Please advise as to how I may open and manually clean the valve.
  • Espressione Master
  • 1,711 Answers
This is a simple problem. The steam valve has some scale deposits which it does not leave to close completely. So when you're brewing the water is with 9 bar pressure so some of it can escape through the steam valve.
You can try decaling the machine a couple of times and leaving the dissolved liquid in the machine for longer time about one hour so this might melt the scale and clean the machine.
Do this the next day and even the day after. If the problem insists then you will need to disassemble the steam valve and manually clean it from scale.
You have some information's in the following links.
http://www.fixya.com/support/r4335301-descaling_espresso_machines_never_use
http://www.fixya.com/support/r6014627-espresso_machine_will_no_steam_purges
http://www.fixya.com/support/r5578817-fixing_traditional_home_espresso_coffee
http://www.fixya.com/support/r5799027-buy_parts_saeco_gaggia_spidem_espresso
Posted on Nov 14, 2010
It leaks like a sieve every time you brew coffee!
I found that ours would leak if the accuflavor knob is turned to much toward "strong"
I moved it to half way between strong and weak and it does not leak anymore.
UPDATE 1/2/16: Ours started leaking again and turning the AccuFlavor knob had no effect. However, when I PULLED UP on the lever (towards the ceiling), the leaking stopped and has remained stopped, no matter what setting the lever is turned to.
Apr 20, 2011 | DeLonghi Caffe Nabucco BCO70...
The water coming out of the steam nozzle is clear but fromthe brew head it is milky looking. I have descaled
That's ok .
The water from the steam nozzle is straight from a boiler.
Where as the brew head is fed from another boiler via the brew unit,so you will still have some coffee in the system.
If you wanted to you can rinse the brew head by making preground coffee without coffee this will flush it clean.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Water leaks from bottom of Saeco Caffe Charisma when brewing
Remove brew chamber, check the back of the white plastic valve make sure the chamber under it is clear of coffee grounds and water, then check the red o-ring on the brew chamber make sure there are no cracks or damaged spots.
Jul 15, 2009 | Saeco Caffe Charisma Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Where do I locate the fuse for the steam nozzle of the Gaggia Classic? - the coffee brews but no steam will come out to froth up -I was advised it was probably the fuse -all othe rparts have been cleaned
If the coffee brews hot then the problem is a blockage on the steam valve nozzle or line. Try removing steam wand and opening valve to see if it works, if it does the problem is in the wand that has been removed. Dismantle parnello and using a paperclip clear out the hole in the end of the steam wand.
Jan 14, 2009 | Gaggia Classic Espresso Machine
It doesn't have enought pressure to brew the shots. The coffee just drips out
The first time I used mine I had the same problem. Try making sure the brew selector is not too far to steam selection. If that doesn't work make sure the basket with the espresso in it is not too tight.
Aug 01, 2008 | DeLonghi Caffe Nabucco BCO70...
Water from steam nozzle
I purchased a Talea Ring in February this year and have exactly the same problem
Jun 05, 2008 | Saeco Talea Giro Espresso Machine
No instruction on how to prime a saeco caffe charisma machine. looked in the book that came with it but there is no instructions for this process
Prime = letting some water out from the water/steam nozzle. Priming means that the machine has not water in the lines. By letting water come out, you are making sure that water fills all the components and is ready to use.
Apr 28, 2008 | Saeco Caffe Charisma Espresso Machine
Cafe verona delonghi
You need to turn the knob on top to the steam logo. then turn the knob on the side to open the steam valve. then when you get all the steam you need turn the knob back to brewing
Sep 11, 2007 | DeLonghi Caffe Nabucco BCO70...
Espressione Caff? Novecento Logo
135 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
