Question about HP Photosmart 3210 Printer
Err.0xc18a0107 - HP Photosmart 3210 Printer
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Walgreens HD303 Blood Pressure Monitor error 3
measurement.
Error Codes
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Ink system failure message on HP photosmart c5180 all in one
tengo una impresora photomart c5180 hp y me produce un error 0xc18a0107
Nov 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure Error:0xc18a0107
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 23, 2009 | HP Photosmart 3210 Printer
Print error code 0xc18a0107 hp photosmart c7180 All in One and will not print.
that was a system error...
How long since that problem occurs..??
I suggest that you need to load another compatible firmware on that printer ...
thank you for using FIXYA!
May 23, 2009 | HP Office Equipment & Supplies
Error: 0xc18a0107 Printer HP C5180 All in One
I had the same problem for a few days.
Each time, I switched on my HP C5180 printer, the Oxc18a0107 message was displayed.
I tried the solution that I found on the net (power off, power on while holding on OK and HELP keys) unsuccessfully ...
Then I bought new ink cartridges and I put them after resetting the printer.
No more error message ... It works well now.
Abbesses
Apr 09, 2009 | HP Photosmart C5180 All-In-One InkJet...
Boot password
how to fix printer hp photosmart c5180 has system error 0xc18a0107 help me please
Jun 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
HP Photosmart 3210 Printer Logo
59 people viewed this question
Seeker5211
Seeker5211
