Service manual canon IR 600 photocopier - Office Equipment & Supplies
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
Adi_Taticu
  • 71 Answers
SOURCE: i have an error in canon photocopier IR 1210 E 245
errors are not described in service manual
trying to put out the power and put it back
if not resolve, you should reset the memory
stop the copier, get out the back cover and looking for jumper JP1, him out, wait 1 min, put in place jumper, start the device. I hope to help information
JP1: jumper plug for power used by battery to back up memory (control data; user data, service
mode data).
Posted on Oct 25, 2009
  • 11 Answers
SOURCE: e000000-0000 on canon ir2200 photocopier how to
this is tadesse E000is the main thermiistor (TH1) has poor contact or an open circuit. the termal switch (TP1) has an open circuit.the main /sub heater has an open circuit .the main power supply PCB is faulty. the DC controller PCB is faulty .you can clear starting service mode 1) press the user mode key *
2) press '2' and '8' on the keypad at the same time
3)press the user mode key * on the contrl panel
(copier, fuunction,clear,ERR
Posted on May 23, 2010
SOURCE: canon ir 400 photocopier
i have ir400 in my machine. first e805 code has been displayed and after that it shows that to load paper. then after e803 code is displayed. please help
Posted on Aug 16, 2010
  • 452 Answers
SOURCE: My ir canon photocopier shows
if you are changing the machine room from cold to warm, it can causes the error code E100, it's a condensation of the laser sensor. to solve this problem you need change the laser sensor PCB or the laser unit. or try to warm up the pcb sensor with a hot air. look at the picture to identify the laser sensor:
Posted on Dec 18, 2010
How can i solve the problem of System error E100 in a Canon iR 1020 photocopier?
You should have a PDF Owner's manual on the software install disk. Troubleshooting section should say what the error is and what to do to fix. Or try this:
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR1020
Apr 02, 2015 | Canon Office Equipment & Supplies
Canon photocopier 2318 service manual
Hello friend, you can find the Canon iR 2318 2422 2420 232 service manual in below link:
Canon iR 2318 series service manual:
http://goo.gl/Ee4H4l
Thanks
Mar 12, 2012 | Office Equipment & Supplies
Wanted service manual for Canon IR 400 photocopier
You can try these links below that list free downloads of the service manual for that particular model:
- http://www.freshwap.net/987/dl/canon
- http://www.instantdownloads.net
- http://www.free-service-manuals.com
Hope helps.
Aug 23, 2011 | Canon imageRUNNER 400S Copier
Canon ir2016 photocopy machine printer software
i want to get the Canon ir 2016j photocopy machine drivers
Oct 20, 2010 | Computers & Internet
I required Canon Photocopier IR3300 driver
Hi, try this link for your driver:
http://www.givemefile.net/drivers/_xerox_and_ifis/canon/ir-3300.html
Aug 07, 2010 | Computers & Internet
I have photocopier canon ir2116j show download stand by please hlep me
these means that your system software is crashed down, you need to upload new firmware. For these you need service support tool, new firmware and you must know how to do it. CALL SERVICE.
Aug 07, 2010 | Canon iR 2016i Black and White Copier
Hi I need to connect my photocopy canon ir
you must put an ip address,on the machine ( system),and the port of the driver you must put the same ip.
Apr 04, 2010 | Canon iR 2016i Black and White Copier
301 people viewed this question
jasbo
jasbo
