Question about Pioneer VSX-D507S Receiver
Turns off 5-10 mins after turned on
It turns on fine and we just moved it into a new room today... after 10 mins or so, the receiver turns off and the phase control symbol blinks.. i can turn it back on but it does the same thing 10 mins later. It is only a year old and pretty darn expensive. What can i do to fix this?
  • stomper209 Jun 21, 2008
    yes, The connection seemed to be the problem, i redid all the wires and everything seems to be perfectly fine, Thanks!
  • jasonw360 Dec 18, 2008
    my phase control shuts my system down if i turn it past a certain level (volume). i am going to check all my connections as well. My system has not moved at all. Although i do have animals. :)
I have checked my connections and it turned out to be a short in one of my tower spearker wires. My system works fine now and pounds like it used to.
Posted on Dec 18, 2008
    President:
  • 624 Answers
One thing to check would be the speaker connections. If this receiver worked before you moved it and only started doing this after it was moved, that could be the source of the problem.
If the speakers are connected improperly it could cause it to go into protect mode after a few minutes.
Also check the speaker wires and make sure you don't have any frayed wire sticking out and touching the chassis of the reciever or shorting together.
The phase control symbol is something I would need to research, I have repaired several of these recievers and do not remember the phase control ever being a problem.
Logic would dictate that something is connected wrong, my first thought is the speakers, but it could be something else. I would go back over every single connection on the back of this unit and double and triple check them all. make sure the positive speaker connections are going to the positive speaker post and negative to negative.
It is also easy to connect the speakers to the wrong jacks on the reciever. You may be bridging a channel or two and that would cause the reciever to get hot very fast and shut down.
If none of this helps you may just have to take it in to a service center. I would reccomend an authorized Pioneer service center. They can at least call Pioneer tech support and talk to Mark, Bernie, or Mike at Pioneer. They are on top of all things Pioneer.
I will be happy to help you further if you need it.
Posted on Jun 18, 2008
  • Dave DeGain
    Dave DeGain Jun 21, 2008
    I am curious if you were able to figure out the problem.
My hisense 32 in hdtv iv had for almost a year has worked totally fine, than today we moved it to a diffrent spot in the room turned it and cable box on for bout 15 mins and come back in room after wiping...
check to see no master power button on rear, other than the cord not being in all the way the set would have to be opened to see if a bad fuse or not......
Nov 04, 2012 | Televison & Video
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
HK AVR25 MKII goes on and off numerous times on cold power up
The relay on the PWR SUPPLY board clicks once when the PWR switch is turned on then 2 to 5 sec. later it clicks again and 'off' it goes.
The small transformer ( standby power) on the board appears to be leaking crud (looks like wood glue) all along one edge.
Can I bypass this relay to see if the power transformer is 'ok'?
Jan 16, 2009 | Harman Kardon AVR 25 MKII
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
No sound from a sony stereo receiver.
Hi there
Have you checked that the speaker on/off switches have not been bumped also. They are often at the left hand end of the amp next to the power switch and easy to turn on. A Tape monitor switch engaged will also give you those symptoms. Check them out and get back to me here if you cant find the problem
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
My asus wont turn on after plugging it in
The squealing sound indicates a fault, as does the flashing lights. It's very hard to narrow the problem down. Since you have recently received this laptop, it would be best to return the laptop under warranty for repair or replacement. It is more than likely fried, my friend. Unlucky.
Sep 07, 2007 | ASUS Z71V Notebook
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
138 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
