Question about kawasaki Full Suspension Mountain Bike Men
Hi since weather has changed my zx9 wont staret just turns over i had the carbs balanced couple months ago i have put new battery on had plugs checked was told there fine oil and filter changed checked all cables and connectors all are good. the choke dont seem to be doing anything but when i got it started once i pulled choke on bit quick and it cut out so i think choke works. also i used a hairdryer and warmed under the tank for bout 5-10 mins and the bike fired up even without the choke or throttle and runs perfect once started and will start straight away when re started could you help cos its doing me ed in
  • 20 Answers
Hi m8t it sounds like a couple of things 1 you my have mioster in the wireloom thats why your useing a hairdryer under the tank..2the timeing my be out or the tappits my be loose reset them...3 the choke my be jammed just make sure that the choke runs freely on the cabs....ps sorry for the spelling...if the wireloom has water damage dry it of and tap it up hope this helps you
Posted on Nov 12, 2010
My Suzuki vitara has been sitting for a couple of weeks. Temps have been hovering around freezing. Just put a new battery in. Car turns over but wont start. ?????
no year car? wow...
no country. sold world over, with 5 more more engines,
miles on car?
miles since last full tuneup.?
when was it last a reliable daily driver? last month or year?
my guess( useless) is it needs a tuneup,
ever heard of spark plugs? fresh and new??
a tuneup makes 99% of all engines start in cold weather,
Ill assume it cranks robustly but I can't hear it?
200rpm is fast robust starter 50 is no good. 50 RPM
a mechanic hears that, and just knows, in 1 nano second.
new battery means nothing, what was CCA spec.
Dec 30, 2016 | Suzuki Vitara Cars & Trucks
I ran out of gas on my Kawasaki ZX9 and it runs not very well now! How do I clean the carbs out?
re-categorized, and tidied up your English. :-)
There are videos. Tank off, air filter box off, disconnect linkages and fuel pipes, remove carbs, clean the bottom float chambers and then the jets. Reassemble and balance the carbs. Not done this for a few years but fairly straight forward.
cleaning kawasaki zx9 carbs Bing Videos
Sep 03, 2015 | kawasaki ZX-9 R Ninja Motorcycles
Im not getting any spark, what are some ways to troubleshoot spark on my ZX9
Hi, Jerome and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or CDI or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.kawasakimotorcycle.org/forum/kawasaki-streetbikes-sportbikes/49265-zx9r-no-spark.html
How to diagnose no spark situation on motorcycle
Kawasaki Ninja ZX 9R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Mar 17, 2017 | 2000 kawasaki ZX-9 R Ninja
Honda 6500is wont start ran about 6 months ago drained fuel put new fuel in still wont start.
make sure you are getting fuel to carb, also check spark plug
Jun 12, 2011 | Garden
Want start in cold weather?
the car won`t start in cold weather even when plugged in alternator was changed 4 months ago just changed battery thinking it was the battery but seems like something is draining the battery overnight? Maybe its a bad connection??Plz help!!!
Jan 22, 2011 | 2004 Saturn ION
Yamaha xs750 starting problem
You need you carb cleaned, air filter cleaned or replaced, and new spark plugs.
I bought XJ750 years ago, not running, cleaned the carbs, installed new spark plugs, and rode her for 5 years
Aug 22, 2009 | Yamaha TX 650 A Motorcycles
Cr125 problems with acceleration
Hi,try the stator, may need rewinding.
May 18, 2009 | Honda CR 125 R Motorcycles
I have a 99 zx9r . when i go around the block it will die then it
Hi I owned a 2002 zx9 and had to replace all the coild packs as well as new plugs and filters, does it just all out die as in loses battery life or just dies then is hard to start? also would check the main feed line into the carbs, see if you can take it loose and lightly blow some air in through the carbs, this will loosen any dirt in the carbs up that could be causeing the problems. Good luck and hope everything works for you as well as it did for me.
Mar 06, 2009 | 1999 kawasaki ZX-9R Ninja
7.3 diesel turbor wont start
It needs to spin over at correct speed so if it is dragging causing slow turn over then yes it can cause
Oct 17, 2008 | 1996 Ford F350 Crew Cab
kawasaki Full Suspension Mountain Bike Men Logo
81 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
