Question about Dishwashers
Miele dishwasher makes a grinding noise at start of cycle, (as soon as door closed.) It then works fine until mid cycle when it grinds again for a further 20-30 seconds. then it is fine.
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
localwonder
  • 6784 Answers
SOURCE: dishwasher motor makes like a grinding noise on start up
Hi. This grinding or hum can be associated with internal electric motor failure. the grinding and humming sounds are warning signs that will ultimately, lead to total failure.The actual term we in the industry use is A.C. hum. This will occur when the internal electric motor windings begin to break apart from the center housing inside the motor casing. this will disrupt the current flow, causing over heating. the grinding is because of the alignment that has been disturbed as well. The solution is to prepare for the replacement of the electrical motor or, you can repair it.
please rate and have a great day.
Posted on Mar 21, 2009
SOURCE: GE dishwasher is making a grinding sound
http://www.applianceblog.com/mainforums/archive/index.php/t-2825.html
Posted on Oct 13, 2008
  • 423 Answers
SOURCE: LGDishwasher makes grinding noise several times during cycle
Please confirm that you have an LG LDS 5811 dishwasher? Approximately how many years old is the dishwasher?
First things first: regarding the 'crud' Run at least one cycle, with no detergent powder added - and when you go put in the extra water, add up to two cups of vinegar plus more water and let it run until it errors. This will not fix the major problem, but staring with a clean sump area (and keeping it clean) is a good start. FYI: Stop using all gels and tablets, switch to a brand name detergent powder-like Electrosol or Cascade. Always use high quality powder in all dishwashers, especially energy and water conserving DWs like the modern LG models.
Next, given that you are getting an E! code, triple check that you do not have a leak, especially directly under the dishwasher. If not, start at the end of the DW drain hose (does it connect to a sink disposal?) follow it back to the DW. That hose must rise to at least the height of the bottom of the counter top or be connected to an Air Gap valve. If the hose does not have that rise in it, your problem is caused by natural siphoning out of the dishwasher into the drain. Either add an air gap (even if you don;t have a sink disposal) or suspend the hose high from the bottom of the counter.
Regarding the filter (mesh screens) in the sump area, while it may be melted, I doubt that melting was caused by the dishwasher itself, because the heating element is well below the filter.
Pull the lower spray arm up and out. Remove the nine phillips screws that hold the filter down and then pull the filter. Wash out the "self cleaning" filter housing.
The LG replacement part for the upper housing with the mesh screen panels is: FILTER ASSEMBLY, MESH 5231DD1001A I also recommend you replace the filter seal: SEAL 4036DD3001A
Then inspect under the filter in the sump area for any debris. Remove it but watch out for broken glass! Use a flashlight and look real close for anything foreign.
Inspect the Impeller, look for damage and confirm that it spins easily but is securely attached.
Reassemble and test out.
Good Luck!
Posted on Apr 05, 2009
vickygomar
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
RE: Miele dishwasher G1472 The door will not close. Does the lock work with a relay, or is just the plastic lock broken down? I should like to have a repair manual of this machine. Where can I find it?
Sorry mate - manuals are hard to come by from miele, only service agents have these and are bound by contractual obligations.
there is a door locking plate located mid top of the dishwasher which latches to the door, a locking mech. # 6022271 located on the door itself.
The locking mech is electrically controlled only when cycles are selected and you push start. The chances are where the latch system which clicks into the mech is likely to be worn or jammed, the door should click into place as you close it and electrically locked during the cycle.
I would say there is a mechanical problem with the machine more so than anything else.
Jul 04, 2011 | Miele G 1472 SCVI 24 in Builtin Dishwasher
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
It has started sounding really, really loud with a long grinding sound and then like a swishy sound for a short break, then the grinding sound again.
Sounds like a piece of broken glass or hard fruit pit stuck in the garburator. Remove the botom rack and disassemble the eniter assembly located below the bottom rack. Keep track of the order of the parts until you reach the stainless steel garburator blade. If you are not mechanicaly inclined, take video of the dissasembley to help you put things back together. You will probably find a foreign object by the time you reach the blade. Continue disassembling the assembly below the garburator to ensure that the drainage ports are not obstructed. Consider re-assembling without the garburator blade to avoid recurring problems. Substitute Garburator blade with routine disassembley and cleaning every 3-6 months. Sadly thats the best way to overcome the failure prone Garburator mechanism. When its time to buy a new D/W, buy one with a filter instead of a garburator. I recommend Miele and recomend against all Whirlpool brands (Maytag, Jennair, KitchenAid, Kenmore, Whirlpool, WhiteWestinghouse, etc.)
When Garburators Jam, you risk overheating that can melt the overpriced circuit board or overheat the motor. Either problem means discarding the dishwasher becasue the repair cost would be too high. The Garburator is a disgusting idea anyway. Instad of allowing food particles to sit at the bttom, the sme particels are minced and sprayed over the dishes that you are trying to clean.
Oct 24, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 | Dishwashers
Whirlpool LSC9355DQO won't spin and makes grinding noise
grinding noises are never a good sign. My best guess is that the motor coupling is shot. Very inexpensive repair if you're handy. unplug and tip the machine back. locate the motor and remove the clips holding the motor/pump assembly to the transmission. carefully remove the motor and if the coupling is shot, replace. put it back together and should be good to go.
Aug 22, 2007 | Whirlpool LSB6200KQ Top Load Washer
Dishwashers Logo
1,663 people viewed this question
Top Dishwashers Experts
Owen Barnes
