Can't find my wep key address - Computers & Internet
  • 1,679 Answers
Click on the link below and it will provide you with the information you need.
Router Detail Link
* Don't forget to rate this solution and write comments
Posted on Nov 12, 2010
Where is wep key location
WEP key is in your router's configuration settings.
in windows open a command prompt (search for "cmd" from the start menu)
in command prompt type "ipconfig"
Look for "default gateway" and remember the ip address listed for it
in your browser (internet explorer, firefox, chrome) type the ip address from the default gateway into the address bar. probably something like 192.168.0.1
once you access the router settings, the WEP key is under the WIRELESS section, called security.
Aug 12, 2014 | Linksys Computers & Internet
Don't know my WEP key
Often times the WEP key is the serial number printed on your router. If that doesn't work, log into your router through your web browser (just type the router's IP address into the browser's address bar and then enter your username and password) and under Wireless Settings or Security Settings or something similar, you should be able to find the WEP key.
May 28, 2010 | Microsoft Wireless Network Adapter Xbox...
How do i find my Wep key for my netgear router
you have to access the GUI of your router. if you dont know the ip address. go to command prompt and type in ipconfig. look for the gateway ip address and type it directly to your I.E address bar. once you are inside the router interface, ussually WEP key is under wireleess security. go over there and check your WEP key. you can also change the WEP key.
Apr 03, 2010 | Computers & Internet
Error code 51330 on the wii.it will not except my
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
Retrieve WEP Key
You can view the WEP key on the router's Web UI. Just go to http://192.168.1.1 (router's IP address must be entered on the address bar). Go to Wireless and then click on Wireless Security. Just copy the key on your notepad and then enter it on the new wireless product.
Jul 13, 2009 | Linksys (WRT54GC) Router
Wep address
WEP address is your security key to get on the wireless network. New access point usually do not have one assigned. You need to get into the router and enter it in, like a password. If you haven't setup the network, then someone else did and you need to get the WEP key from that person. If you can get it, then you could reset the router to factory defaults by pressing and holding the button in the back of the router for 30 seconds. Let the router reboot and look for a wireless network called "LINKSYS" or "DLINK" or something like that. You should be able to connect without entering a WEP key. If your computer asks you for one then leave it blank or look in the manual for the default WEP key.
Mar 28, 2009 | Linksys Wireless-G WRT54G Router
How do I get a wep key and what is it?
A wep key is a type of internet security (mostly used on routers) to prevent any unauthorized access to their internet connection. And to get a key, go to the router you wanted to connect to and ask for the wep key and to add you to their mac address book, or if you own one, go to the txt. document that was downloaded on your desktop and look at where it says network security key, and if your router has a mac address filter, add your ds's mac address to the mack address book on your router. then connect and type the key.
Nov 11, 2008 | Nintendo DS Lite Console
I am visiting my aunt, she has att broad band with wireless, I put the wep key in and it gives me limited or no connectivity. It gave me a 168 address so I manually put in a 192 address, got rid of limited...
First take off WEP.
Next, ensure DHCP is enabled on router.
Don't set a manual IP address in computer, it should auto detect.
You probably have the WEP key wrong
Use the HEX WEP key in windows, do not use a pass phrase.
Aug 17, 2008 | Computers & Internet
I am attempting to secure my network through this router which at this time is open for the whole neighborhood to see
Here are the diffenent types of Security Settings possible with a wireless router: (how to set this depends on the brand of router)
Security Mode: You may choose from Disable, WEP, WPA-Personal, WPA2-Personal, WPA-Enterprise, WPA2-Enterprise, or RADIUS. All devices on your network must use the same security mode in order to communicate.
Capture(wlansec.wpapersharekey) WPA Personal:
Capture(helpwpa.phase8) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase9) WPA Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase10) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wpa2persharekey) WPA2 Personal:
Capture(helpwpa.phase11) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase12) WPA2 Pre-Shared Key: Choose a unique key to authenticate with other devices on your network. The Pre-Shared Key must be between 8 and 63 characters in length.
Capture(helpwpa.phase13) Group Key Renewal: This settings determines how often your group key changes.
Capture(wlansec.wparadius) WPA Enterprise:
Capture(helpwpa.phase14) WPA Algorithm: You may choose from TKIP or AES.
Capture(helpwpa.phase15) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase16) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase17) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase18) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wpa2radius) WPA2 Enterprise:
Capture(helpwpa.phase19) WPA2 Algorithm: You may choose from AES or TKIP+AES. Choose TKIP+AES if you have both WPA and WPA2 devices on your network.
Capture(helpwpa.phase20) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase21) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase22) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase23) Key Renewal Timeout: Determines how often your keys should be renewed.
Capture(wlansec.wep) WEP:
Capture(helpwpa.phase24) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase25) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase26) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase27) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Capture(wlansec.radius) RADIUS:
Capture(helpwpa.phase28) RADIUS Server Address: The IP address of your RADIUS server.
Capture(helpwpa.phase29) RADIUS Server Port: The port your RADIUS server uses.
Capture(helpwpa.phase30) Shared Secret: The shared secret set on your RADIUS server.
Capture(helpwpa.phase31) Default Transmit Key: The key you would like to use for transmitting WEP keys.
Capture(helpwpa.phase32) WEP Key Bit: You may select from 64-Bit or 128-Bit encryption.
Capture(helpwpa.phase33) Passphrase: You may enter a passphrase consisting of any keyboard character to be used to generate a hex WEP key. Passphrase option is only supported when you are only using Linksys devices on your network.
Capture(helpwpa.phase34) Key 1-4: You may enter a WEP key manually. You must use only hex characters (0-9 and A-F). 64-Bit WEP requires 10 hex characters. 128-Bit WEP requires the use of 26 hex characters.
Jul 03, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
