Question about Zanussi 23 in. ZKT641H Electric Cooktop
THE 2 LEFT SIDE HOT PLATES HAVE STOPPED WORKING. THE 2 RIGHT SIDE ELEMENTS ARE WORKING AS NORMAL. ANY IDEAS?
Residual indicators & right hot plates don't work!
LOL like the way you put that about FAULTY ELECTRICIAN . and that would be my guess also .
Feb 11, 2016 | Cooktops
Replaced element on frigidaire oven and oven still not working
Good Afternoon Friend,
I understand you've recently replaced the elements on your Frigidaire oven and that it is still not working. May I have your model number please? The serial tag, which lists your model number, is normally located in the storage drawer, on the right side if you have a range. If you own a wall-oven please check the front of the oven, on the left side, as you open the door. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better determine what may be causing the issue at hand. Thank you! - Z
Sep 07, 2014 | Frigidaire Stove / Oven / Range Cooktop...
How to replace an element
This could be a couple of issues, but unfortunately if it's your element, you would have to replace the entire element, not just the middle part. What's the rest of your model number? I can find a part number for you. (KECD806R****)
May 17, 2014 | KitchenAid KECD806R 30" Electric Cooktop,...
My neff helectric hob two of the plates are not working
Sounds like the heating elements burnt out.
Dec 12, 2011 | Cooktops
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Apr 25, 2010 | Kenmore 30 in.44084 / 44089 Electric...
Chef Supreme Co-ordinate Series Ser. No.: 2004434294 Manuf. No.: 091E11SE1 Sales No.: RETSZW Hot plate not working & suspect bad element or thermostat? 1. The element is not an exposed coil, but rather...
this could be a 220 v unit and one side of the lines is out . ck your power at the breaker and at the cook top . if power is ok I would think it's the control sw . and not the plate .. you will need a volt /ohm meter to test . whirl / g e / frigidair / have genric switches that should replace yours .. hope this will help mm
Dec 03, 2009 | Cooktops
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Zanussi 23 in. ZKT641H Electric Cooktop Logo
80 people viewed this question
Top Zanussi Cooktops Experts
fyigen
Brian Coughlan
Tom Chichester
Are you a Zanussi Cooktop Expert? Answer questions, earn points and help others
