Question about JVC GR-D30U Camcorder
NO PICTURE ON CAMERA MODE?
Whem i put my camera on camera mode i have no picture the screen display only say ?lens cover. what shold i do ?
  • 3 more comments
  • marc1968 Aug 13, 2008
    No picture on lcd display or camera. Able to record sound but no video. Cam was not damaged physically. Charged the battery, changed the various options in menu, reset the cam. Still no display.
  • gigs95 Aug 27, 2008
    Having the same problem...any solutions?
  • Anonymous Nov 24, 2008
    i have the same problem with my jvc gr-d30u and i havent use it much,can any body help
    my jvc grd-30u camcorder shows a lens cover error even with the cover off can anybody help me thanks
    my jvc grd-30u camcorder shows a lens cap error even when the cap is on
Why won't my Rebel T3 take pictures in the AF mode?
First Try a different lens on the Camera to see if its the body or the lens, Most of the time its the lens, If its the lens then it has to be repaired by a repair shop, Cost to repair is $68.00, Body: Check in the menu settings under Display reset it there to the length of time you want it to go on or off.
Jun 23, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
My camera will turn on then go off and the lens will not go out how do i fix this?
The manual is a bit confusing. I do have a power shot, but is is a bit younger. My camera does have 2 On buttons. One to put it in shooting mode. And one to set it in display mode. If I press the display button (arrow right) the lens stays where it is and I only can see pictures I took. When I press the on off button the lens comes out.
I think you only have to switch the main dial to the camera logo (shooting Mode) and then press the Disp button, to shoot pictures and if you want to view pictures, you turn the dial to playback Mode (arrow to the right) and press the Disp button.
If it works, no fix, just knowledge about how the camera works. It is all in the manual.
Jan 14, 2014 | Canon PowerShot A520 Digital Camera
Pics are blank in viewer
there are many reasons that no picture is displayed:
1. there is no picture in the first place. (camera lens closed when picture was taken)
2. you are not on display mode (toggle to display mode not "take picture" or capture mode)
3. defective memory card.
4. you are on display mode but on another sub-mode which does not display pics... (toggle to display, details, etc...)
Aug 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 13, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
My brand new just put batteries in it powershot is displaying NO IMAGE. the lens won't even pop out! what the hell?
LOL, sounds like you're in "picture review" mode. Except that you haven't taken any pictures yet, so there's "NO IMAGE" on your card just yet. To take a picture, you need to put your camera in "camera" mode. Slide that tiny slide switch in the upper right all the way up until it's next to that little red camera. Now take a picture.
Jan 15, 2009 | Canon PowerShot A590 IS Digital Camera
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
JVC GR-D30U Camcorder Logo
123 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
