Question about Refrigerators
Kitchenaid ksra25i refer ice maker
I have the above refer and it has stopped making ice. i replaced the ice maker about a year ago and it looks to be in good physical shape - no rust or corrosion. there is ice in the tray and the fingers are at the 2 o'clock position (out of the ice pointing at the door). the led blinks twice pauses blinks twice again etc. any thoughts? thx
  • 3422 Answers
SOURCE: KITCHENAID ICE MAKER STOPPED WORKING LED
HI,
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Posted on Oct 10, 2008
mark_37388
  • 100 Answers
SOURCE: kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Posted on Mar 30, 2009
  • 351 Answers
SOURCE: Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Posted on Apr 30, 2009
  • 523 Answers
SOURCE: ice maker wont make ice, light blinks twice in a
the eyes are bad
Posted on Jul 09, 2009
woodchuck789
  • 4070 Answers
SOURCE: water leaking/freezing in bottom of freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Posted on Jul 12, 2009
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
Jul 08, 2017 | KitchenAid Kitchen Aid Superba Series...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
No water to the ice maker
The light (receiver) , should light twice , pause , 2 times , pause , and so on . If you close the left flap (emiter) , the light should go off . This is normal operation for the optics .
Check the black tube (fill tube ) , above the ice maker , to be sure it is not iced inside , blocking water flow . If it is , then the water valve needs to be replaced , due to seeping ( not closing completely ) . Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , and the black tube is clear , replace the water valve . If the ice maker does not dump , and the frozen cubes stay in the ice maker , then replace the ice maker . Also , check the coils under the refrig , to make sure they are clean from dust , lint , pet hair , etc .
Sep 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
The ice maker stopped working, gradually over a 3 day period.
It sounds like your harvesting motor failed. If you feel comfortable working on it, you can pull the ice maker out and remove the harvest motor and have it replaced. If you don't feel comfortable pulling out the harvest motor, pull the ice maker and replace the whole unit. They are a little tricky getting them out but if you take your time and don't rush, it is a doable fix for the typical do it yourselfer
Jan 11, 2018 | KitchenAid KSRB25FRBX Aluminium Side by...
Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Sep 16, 2008 | Refrigerators
Ksra25i kitchenaid refer ice maker
Probably the infrared emitter and receiver that are on opposite walls just inside freezer door near ice bucket.
Oct 31, 2017 | Refrigerators
Not making ice
canyou acess theice amker assy itself??
can you look intor the icemaker make sure nothings blocking ice maker from turning(ice cubed jammed in )
look into the fill tube make sure itsnot frozen
thinkin htis machin hasan electronic "eye" if so htere a trouble shoooter under the kickplate explaining the mechanism
lastly theres a white cover plate on the front of the assy. remove the cover and loook at the white gear in the center of unit. look real close at the tabsholding that gear on.MOST common causeof failure is the ice torques the main gear and those tabs snap. if htats the case , replace the ice maker assy.
Mar 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
