Question about Moen 1 Handle LavatoryWith Drain Assembly - 64621P - Polished Brass
Hard to pull up handle - Moen 1 Handle LavatoryWith Drain Assembly - 64621P - Polished Brass
    Genius:
  • 1,015 Answers
Are you asking about faucet handle or pop up drain . If you are referring to faucet handle the easiest thing to try first is to remove center cover from top of handle. It's the one with the moen insignia or name on it. These are usually just a friction fit so use a small blade screwdriver or knife blade to carefully remove cover. There is a screw that holds handle on cartridge. Remove screw and gently remove handle by pulling up. If you have not shut off water supply valves this will open valve and run water. Push down on carteidge stem to shut off water. Use a penetrating oil such as WD-40 and spray around cartridge.Allow a few mins. then pull cartridge stem up and push it back down several times spraying with penetrating fluid several times. You can move stem by gripping with pliers. This should help free cartridge . If this helps you can save on service call. Reinstall handle with screw and center cover. Hope this helps. Thanks
Posted on Nov 12, 2010
Testimonial: "I followed your directions but did go ahead and replaced the cartridge myself. First time for that - but was able to get a new cartridge at Lowes for"
Bathroom sink single handle danze faucet. I removed set screw, but the handle won't come off. How hard can I pull?
Alot of variables there. If it's really old you must be extremely gentle. I have had them crumble into pieces in my hand. If it doesn't appear corroded around the edges and is in good shape, you should rock or pry gently with a non marring tool (putty knife covered by rag) alternating sides to break it loose. A penetrating oil like PB blaster can be used if you can let it sit for a day. Just straight pulling is not wise. Tapping (not pounding) can be helpful. You are just trying to break the bond between surfaces so the vibration of lots of light tapping will sometimes do it.
Jun 09, 2016 | Danze D203112 Melrose Single Handle...
Tighten door handle on Whirlpool Conquest refrigerator
You need to remove the handle befor eyou can tighten the mounting bolt behind it. T remove the handle just grab it and yank UP quick and hard. The handle will unclip and release, then you can tighten the bolt down and re-install the handle.
How strong do you have to be?!!! Trying that and it won\'t unclip. Not sure how hard to try--or will you break something?!!
You have to pull up pretty darn hard with a jerk. That is how both handles are removed on these conquest refrigerators
Sep 01, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Clutch handle hard to pull
How did you check the cable???? Check the release mechanism on the ride side of the transmission, balls and ramp etc.
Apr 20, 2014 | Harley Davidson FXDL - FXDLI Dyna Low...
Rear door handle snapped off.
remove the inside trim card-there's a pull handle with bolts or screws remove those then the rest pops off-can be hard to pull off-after this is off you should be able to get to the nuts that hold the handle--cheers Denny
Nov 08, 2013 | 2006 Toyota Sienna
Handle very stiff, hard to operate. Hard to pull up to open tap. It is 10 years old and has been used very seldom. I can get the handle off, remove the U clamp, but can not pull out the spindle, or...
You need to purchase a moen puller it can be purchased from most supply houses such as Home Depot or Lowes and as you tighten it up it pulls out the cartridge.
Aug 29, 2011 | Moen Home
Tailgate has been hard to open for years. Had to pull handle up very hard and continuously had to pull it harder until the handle finally broke. Want to fix problem to make it open easier and replace...
after you buy and install a new handle remove the access panel on the inside of the tailgate, lube all parts with WD40 also the locking devices at either side of the gate. Also make sure there is no body metal dented inward that could impead the moving parts. WD40 is going to make your day use it generously!
Sep 10, 2010 | 2002 Toyota Tundra
Cannot start. hard disk not found
try the following:
1.Unplug it, then just try to use it again. Also you can reset the PS3 to default settings by holding in the touch sensitive power button for around 10 seconds untill it beeps.
2.Take a screwdriver and unscrew the blue screw and then pull out the hard drive. (Don't unscrew the other screws, just the Blue one).
To pull out the hard drive you need to take the little metal handle and pull it to the right, then pull it out towards you.
After you take out the hard drive, just put it back into the PS3.
To put the hard drive back into the PS3, use the little metal handle on the front of the hard drive and push it to the left while the hard drive is inside the PS3.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
I pulled too hard on the inside door handle now the door wont open from the inside the latch doesnt seem to catch
likely the rod from the handle to the latch has fallen off or the handle is broken where the rod attaches...you need to take the handle off and perhaps the door panel as well and take a look in there. It isn't hard to do but too long to write out. Either get a chiltons or haynes manual or just be careful and remove all screws. the bottom part is held on by push in "Christmas trees" or clips and just pulls out.
Feb 22, 2010 | 1992 Jeep Cherokee Sport
Problem opening d/door bmw x5
Hi remove the door card, you may need to reposition the rod, they sometimes bend making it harder to to reach the open position, most likely you will be able to fix this at no cost, just bend the rod back where it should be.
regards
dan
Feb 01, 2010 | 2001 BMW 5 Series
How do I disconnect the electrical wire plugs from the door handle in order to replace the handle? The plugs won't pull straight off and so I am wondering if there is any piece of equipment needed to...
first shut off the power to the dish washer. The plugs are just verry hard to pull off. You may brake the switch on the old handle but if you have the right new part it should have new switches on it. Just pull hard side to side wiggle off.
Nov 03, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Moen 1 Handle LavatoryWith Drain Assembly - 64621P - Polished Brass Logo
223 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
