Question about HP Pavilion dv1000 Notebook
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
  • HP Master
  • 5,660 Answers
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Posted on Nov 12, 2010
Hp dv7 wont turn on
It sounds like your power adapter is not putting out proper voltage...
Try removing the laptop battery and see if the laptop will power on when plugged in with no battery connected. If it will not power on this way, then test with another power adapter. If still no good, then it should go in for service. Please let me know if this helps or not.
Joe
Apr 24, 2012 | HP Pavilion dv7-1137us Notebook
HP Pavilion DV7-1245 runs on battery, but not with the power cord
If there is a light on the charger? check to see if is illuminated when plugged in the mains.
Could be a faulty power supply lead, check for broken lead near the plug that plugs in to the laptop. The socket it'self could be faulty, if it is then the laptop will need to be stripped down to repair it. Usually it's only a matter of resoldering a joint but it's not cheap because of what's involved.
Jan 24, 2012 | HP Pavilion dv7-1245dx Notebook
I have a HP Pavilion DV7 and it keeps shutting down at random times.. When I turn the laptop back on, it starts up normally besides the improper shutdown screen. It has only happened twice, but its been...
some times can be like as thermal shutdown.
you can check it when using get so hot the back side of the laptop.and you can see reduce the output
of air flow from the cooling fan.and that air flow is get very hot.
for that problem, need to service the cooling fan.
other vice need to check the battery. its go bad, via in small power drop pc goes off.
Dec 05, 2010 | HP Pavilion dv7-1240us Notebook
HP Pavilion dv7-1245dx will only run on battery power.battery will not charge?
The power adapter could be faulty or the power socket in the notebook could be faulty.
Please click on this link to determine the fault and fix :-
Normal 0 http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Oct 13, 2010 | HP Pavilion dv7-1245dx Notebook
Hp dv7-1245dx does not get power when plugged in
First Check your Adapter, It should have LED glow if its working
Second check that your Power Socket is working fine or not. You can try to connect with different Power Socket.
If still its not working. Remove the Battery and connect the Power. Check if its working.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | HP Pavilion dv7-1245dx Notebook
HP Pavilion dv1000 Notebook Logo
223 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
