Question about Kenwood VR-405 Receiver
Kenwood KRA 5050 No power
I moved and when I unpacked my older Kenwood, It was dead. No standby or lights of any kind. All fuses are good and I checked that power is getting to the power supply. Any ideas? Did the movers manhandle and break something? No sign of impact or damaged PC boards. Help!
Thanks, Jay
  • 2,071 Answers
I think the movers mishandle your unit that why it happen like that.It needs to reheat or resolder because the solder holding the spare parts are loose or crack,so when it resolder already performance will come again .That all Txjay , just for now.
Posted on Jun 18, 2008
I have a Kenwood krx-89 standby light on please help
Krx-89 stand by light wont turn off - Fixya
www.fixya.com/support/t14712608-krx_89_stand_light_wont_turn_off
Oct 20, 2012 - krx-89 stand by light wont turn off Stero doenst play is it because thestand by light is on? How do i turn off - Kenwood Audio & Video Receivers ...
How do you turn off standby on a kenwood krx-89 stereo ...
www.fixya.com/.../t15447523-turn_off_standby_kenwood_krx_89_ster...
Dec 20, 2012 - Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left ...
Read - Document Download
Dec 14, 2015 | Kenwood Audio Players & Recorders
Hi, is the red light that says power On? If not, it could just be the fuse since I had the same problem. If you take the lid off, it should be in the left rear and is a 250v 6amp fuse. I had the same problem where only the standby light and the input lights were on. Neither the radio and cassette lights were on.
Dec 20, 2012 | Kenwood Audio Players & Recorders
Lc220emz will not turn on
If total dead, follow the power cord inside the set to find the fuse, look to see if its good or not.
If you get some light of any kind on the set (power, standby etc) that would be a different issue---question here only says will not turn on.
Dec 05, 2012 | Emerson Televison & Video
No power going to LG 42 inch plasma, tried changing fuse in plug and tried a different power lead and still nothing (no standby light etc)
since you have change the fuse in plug, this indicate that your plug is okay, the likely problem is from the television which will require you to open the television to check for fuses, bulged capacitors, but if otherwise your power supply is dead.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help.....
Jun 16, 2010 | LG 42PC3D 42 in. Plasma Television
Kenwood VR-509 Receiver won't power up...
Check all your speaker wires for shorts, especially behind the amp, doesn't take much for something to throw a spanner in the works, like when cleaning house and moving stuff around.
Oct 03, 2009 | Kenwood VR-509 Receiver
I hooked up my speakers when I moved reciever the wires shorted it out and now the stand by light is on and reciever does not work
first fined the short on the wires then replace the fuse o the unit if that does not work then the unit needs to be replaced
Jul 13, 2009 | Kenwood KDC-138 FM / AM Receiver
Reciever won't power up
HI, this amp may need to be reset. also, i would check the voltage selector on the back side to make sure the switch is set to 110-120v. once this is done, you will need to reset the microcomputer. here is the procedure.
The microcomputer may malfunction (unit cannot be operated,
or shows an erroneous display) if the power cord is unplugged
while the power is ON, or due to some other external factor. If
this happens, execute the following procedure to reset the
microcomputer and return the unit to its normal operating
condition.
Procedure- Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER key.
ok, after this reset, if your receiver isn't operational, it may have serious damage to its power board.
Mar 07, 2009 | Kenwood VR-605 Receiver
Unit fails to power up
bad unit in power take it back if u just got it my fav is harmen kardon and kenwood 7.1 thx good prices too does everting way it should last forever
Jan 19, 2008 | Onkyo TX-SR605 Receiver
Face plate wont move
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Jul 25, 2006 | Kenwood KDC-7009
Kenwood VR-405 Receiver Logo
196 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
