Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My lift-master garage opener works just fine from wall button, but will only open but not close from any remotes (from car or original remotes) If I open it with remote and immediately close with wall button it won't even open again using remotes for some time. I have re-programmed all remotes and replaced batteries, but this only helped for a few minutes. It is a model 1245R, 1/3 HP, 75 Watt Max, P/N 41A5021-1C, 06/98. Please help. Thanks
We have the same model and similar difficulties. We were told it's a bad antena. Not sure if there is anything we can do about this. Sometimes it works with the remotes, sometimes not. Always works with the wall switch, because that's wired.
Posted on Mar 09, 2011
  • Anonymous Oct 04, 2013
    My old garage door opener used to cause me so many problems but I switched to the liftmaster in Calgary and I haven't had one problem with it.
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a lift Master door and the remotes work fine but the door will not open or close using the wall button or the keypad.
Are you sure you aren't stating the facts just the opposite of what they are? That would be a fairly common complaint.
Aug 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
Master lift remotes suddenly won't work. Wired panel button works opening and closing door.
Make sure the light in the wall control is not blinking. If it is press and hold the lock button on the wall control for 3 seconds.
Feb 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Lift-Master Security remote garage door opener. It has a new battery. Can it be reprogrammed or do I have to replace the remote?\r\nThank you for your assistance. Model number971LM. It will...
ANY TIME YOU CHANGE THE BATTERY IN A REMOTE IT NEEDS TO BE REPROGRAMED.
ON THE CIRCUIT BOARD YOU WILL FINS A SQUARE BUTTON.
PRESS AND RELEASE NOW HOLD DOWN THE BUTTON ON THE REMOTE FOR ABOUT 20 SECONDS. WHEN YOU PRESS THE REMOTE THE NEXT TIME THE DOOR SHOULD OPEN.
Oct 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1021499A do not have the remote and do not know the code Please help, what type of remote do I need and how to program it The garage door works (open/close) with wall mounted button
You need to get the correct model number which you should be able to find on the end closest to the door. Any door opener service company will be able to help you.
Aug 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My access Master 350 will not open or close when using remotes
If the light in the wall control is flashing your opener is in the lock/vacation mode. Press and hold the button with the lock icon for 3 seconds. If this is not the case your logic board is bad.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door won't close
It sounds like the door sensors have been bumped or somehow gotten misaligned. Tweak them until the light on each one is lit and not blinking. They must be pointed at one another.
May 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
618 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
