Question about Garden
After tightening the chain, the chain becomes loose, all bolts are tight
    Brigadier General:
  • 4,088 Answers
Make sure the bar and chain are being properly oiled, the chain is properly sharpened and adjusted just up to the bar lower edge, but not so tight that you can't turn it by hand. Check the bar's nose sprocket for free turning (with the chain off). I'm assuming that this is not one of the auto-tensioning saws. Make sure the chain adjust 'tang' has dropped into one of the large holes at the drive end of the bar before tightening. You may need to remove the bar and chain to inspect the mounting area for obstructions. Also, start the engine and observe oil oozing out of the side port where the bar fits up to. Hope this helps!
Posted on Nov 12, 2010
Loose left peg, can't get to tighten tight quarters. allen tool, bolt, screw? thanks
Tight spot. I put mine up on the center stand and got a short allen wrench (socket too fat to fix under or over chain) and slowly tightened. If chain is in the way, loosen the chain and try again.
Jul 16, 2010 | 1996 Triumph Trophy 900
Chain has become loose and will ride off gears while in use
If its a singlespeed:
Examine the tightness of the bolts that attach the axle to the frame by loosening then with a wrench. If it was loose that could have been the problem.
Now check the alignment and equal spacing of the wheel inside the frame. Pull the wheel back in the dropouts so the chain has an inch or two of looseness. Lightly tighten the bolts and check again and crank the wheel with the pedals and spin. Check the chain and equal alignment of the wheel. Tighten the bolts that attach the wheel to the frame.
If its a quick release, make sure that when tightening you apply a good amount of force to close the lever at least 90 to 100 degrees. And do all of the above.
Feb 09, 2010 | Cycling
CHAIN AND BAR KEEPS LOOSENING UP AFTER 3 TO 4 CUTS. RESET TENSION AND BAR AND LOOSENS AGAIN AFTER 3 TO 4 CUTS.
Are you holding the nose of the bar up as you tighten the bar nuts?
You loosen the bar nuts and gravity pulls the bar down. You check the chain and the tension is correct, tighten bar nuts. Begin a cut and the bar slowly moves upward (no matter how tight the bar nuts) and the chain becomes slack.
19d6408.gif Chain adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
One more likely possibility, is the chain isn't being oiled.
Checking chain lubrication
Aim the tip of the bar at a light colored surface about 20
cm (8 inches) away. After 1 minute running at 3/4 throttle
you should see a distinct line of oil on the light surface. HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I thighten the chain on a 99 Kawasaki ZRX1100
Near the back of the rear sprocket assy you will see a bolt facing forward. This bolt, when tightened, tightens the chain and visa-versa. To adjust the bolt, loosen the locking nut a just a little bit then adjust the bolt itself. It is best to make this adjustment while the rear wheel is off the ground, so you can spin the wheel and feel for chain tension. Once you have adjusted the chain tension to where you can just barely wiggle it 1/4" tighten the locking nut back against the frame. It is important to get this nut tight, as if it loosens, so will your chain.
Don't overtighten the chain as you will wear it out more quickly and wear down the sprocket teeth (expensive repair). Too loose and you risk a chain skip at high torque.
Aug 29, 2009 | kawasaki ZRX 1100 R Motorcycles
How to tighten a loose chain
To tighten a loose chain you need to pull the cotter key pin from the rear axle then loosen but do not remove the nut. It just has to be loose enough to slide in the swingarm. At this point there are tension adjusters on the ends of the swing arm you tighten them to take the slack out of the chain. NOT TO TIGHT! You should have 1 inch of play in the chain this is up down play not front to back. I push the chain up the highest it can go and measure how far it falls. NOTE: TURN THE TENSION ADJUSTERS THE SAME AMOUNT THE SAME DIRECTION IF THE AXLE IS TWISTED YOU WILL THROW THE CHAIN. This can make for a bad six months!
Aug 19, 2009 | 1998 Suzuki VZ 800 Marauder
The chain has come off my bosch ake 40-19e chainsaw, how do I get this back on?
first loosen the bolts that hold the bar in place. then find then loosen the adjustment screw. Once it is loose, the chain will go back on the bar. Then tighten the chain so there is only about 1/8" movement. (You will want to tighten the bolt so they are snug, when you are tighting the chain) Once that is complete re-tighten the bolts completely.
Jun 08, 2009 | Bosch Garden
Loose chain on Husqvarna 41
first you have to loosen the two bolts on the brake cover . next find the flathead screw located next to the begining of the bar on the inside, facing engine. turning the screw will bring the bar out or in. remember you dont want the chain super tight you want it loose. usually just enough to let the teeth slide a little bit off the bar. once you have the chain were you want it tighten both bolts, and be careful not to move the bar as your tightening. i hope this helps, let me know if you dont understand something i said clearly.
Apr 03, 2009 | Husqvarna Chain Saw 20" Bar
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
Chain becomes very loose with little use
the problem with torqueing the nuts is that it's not enough tighting.i tell my customers that you need to tighten them as tight as you can get them.the nuts will not vibrate loose then.don't worry about breaking the studs they are very hard.
Feb 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Farmhand chainsaw chain tightens too tight for motor to move chain
Make sure the chain is not over tightened. When adjusting the tightness, ensure there is at least 1/8" of looseness by pulling up on the chain in the middle of the bar and releasing it. If a chain becomes overheated because of leaning on the saw when the chain is dull, or lack of oil on the chain, it may expand in the track and not turn freely.
Marlyn, Mountain, Ont. Canada
Oct 02, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
