Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
I by accident sucked up the corner of a sheet into the powermate of my vacuum. I turned the vacuum off and pulled out the sheet but now the powermate is no longer working (suction works fine) Is this something I can fix on my own?
    Novelist:
  • 147 Answers
These power heads have a kill switch on them. Not exactly clearly labeled.
the kill switch reset button should be on the right side of the unit as you look down like you are using it. you may want to try pushing it with the power to the power brush on. Upon resetting the button there, the power
head should start no problem.
Good luck with that.
Mark
Posted on Nov 12, 2010
Sucked up a string and now roller isnt moving
turn the unit off and unplug it - get a razor blade - turn the unit on its side or back which is easier for you to see the bottom of the cleaner and the string wrapped around the ball and connecting area - use the razor blade to cut only the strings and remove the string from the ball
Jan 15, 2013 | Kenmore 23612 Progressive PowerMate Bagged...
Works in FLOOR position but not in CARPET.
The power nozzle has a reset button. Push that and that should fix the issue. You could of sucked up the corner of a piece of carpet causing the brush roller to become jammed. If that doesn't work, there could be a problem with the hose. The hose perhaps isn't providing the power to run the power nozzle.
Oct 12, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Carpet roller will not turn. Vacuum still sucks up dirt
You may need to replace the belt that drives the roller head. They wear out and break, or maybe it has just come loose. Also check for string and thread wound around the roller wheel axles, that is a common "culprit"
Jul 21, 2009 | Kenmore 23913 Progressive PowerMate Bagged...
Vacuum only turns on in reclined position/pull out hose broken
Per the Dyson Web Site I found the solution. Although I cleared all the filters/possible clogs the vacuum had over heated disabling the pull out attachment and power button except when in the reclined position. After clearing the filter and waiting an hour for it to cool it was back to working like normal.
Jul 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Clogged hose
if you have a drain auger then you can stick it in until it won' go any further then you have hit the sock.turn the cable and grab the sock and pull it to the surface.please leave feedback
Mar 30, 2009 | Electrolux Central Vacuum
I sucked up a sock in my powermate, and can't get it opened to see what the problem is. It won't work.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=820548
Generic problem for all Vacuums
I sucked up a sock
Posted by DFundis on July 22, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do is to see if you can open the power mate or powerhead, the sock is jammed in there and blocking the path of the dust and dirt. There should be some screws on the bottom to release the bottom plate or the top cover will come off, it would be one or the other It probably is stick in the gooseneck the swivel neck portion of the vacuum and or the wands or hose. If you need further help look in the owner’s manual or contact your local vacuum cleaner dealer in your area or call Sears cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Vacuums
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Mar 25, 2008 | Kenmore 23913 Progressive PowerMate Bagged...
Performance indicator light
check to make sure the bag isn't being sucked into the air filter. open the access door where the bag is and you'll see the air filter at the bottom. to check, leave the door open while you would see the performance indicator light on, and then pull up the bag. this is one of many solutions i'm sure to the performance indicator problem.
Oct 17, 2007 | Kenmore 23913 Progressive PowerMate Bagged...
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
150 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
