The fuser assembly light has come on and my copier will not work. It is a Xerox XC1040. Do I need to replace the entire assembly cartridge ?
  • Edwin Martens
    Edwin Martens Nov 12, 2010
    There is no fuser error light on this copier. The error for the fuser is an H4 or similar code which will show up in the numerical display where the number of copies is usually displayed. If you have a red light on the display then it is going to be for toner, drum, paper jam, etc. The light for the toner looks like a stack of 6 dots. The drum light looks kind of like a aa battery symbol or a small barrel.Please let us know what light is on so we can assist you further.
    Thank You for using Fixya.
  • 185 Answers
You can clear the Fuser error by entering diagnostics. Your fuser may need to be repaired though, so your error might return.
Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode. The screen will go blank.
To clear the fuser code, select '14' followed by 'Print', then exit diagnostics.
The fuser 126K07390 has been discontinued but people can sell the sub-parts or rebuild them for you.
Whit Item, Inc.
Posted on Nov 29, 2010
I have a xerox xc1040 copier. The paper jam light is stuck on (it is the red light in the center of the display). I have gone through the entire sequence of recommended steps in the Xerox PDF files for...
Sounds more like the drum life chip has expired. Either replace the drum unit or the chip .
I can't remember if the xc1040 has a chip, or if its the one with the gears on front that has to drop a flag in order to reset the drum count.
Either way, I believe replacing the drum unit is the solution to your problem.
Dec 13, 2010 | Office Equipment & Supplies
Getting code H3 on Xerox XC1040 ????
H3= High Fuser Temperature. The fuser 126K07390 is bad and needs to be replaced.
Whit
Item, Inc.
Oct 05, 2010 | Xerox Office Equipment & Supplies
Xerox XC1040 that keeps jamming
sounds like the fixing unit needs to be replaced, give a call to any copier dealer that services lexmark and see what it'll cost for a replacement fuser, with that info you'll be able to tell if you want to fix or trash it.
Apr 13, 2010 | Office Equipment & Supplies
I need to replace the fuser gear on a XC1040
You have to remove that small cover on the bottom of the frame. It has 2 phillips screws to remove it. it is the cover about 3 inches high that runs around the lower front part of the machine.
Once you do that, you only have to remove one screw , unplug the heat rod and lift the fuser up and out. It really is pretty easy.
Mar 08, 2010 | Xerox Office Equipment & Supplies
Xerox model # XC1040 flashes H4 when turned on will not make copies ? code
H4 is a fuser error code. it basically means that the fuser is heating up. from what i can see the fuser lamp alone will be about $60.00. that would be the best case scenario if the rest of the fuser parts are ok. the upper fuser roller is 135.00 and lower 144.00.
Oct 16, 2009 | Xerox Office Equipment & Supplies
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
I have a Xerox xc1040 that works fine most fo the
Yes these problm occurs frequently xc1040 . you ned to adjust the paper tray properly. then shake the bunch of papers so that the paper which are sticked are freed.
Jun 16, 2009 | Office Equipment & Supplies
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
Xerox 416si print or copy are dirty
the problem is upper heat roller of the fusing unit are defective.try to ask xerox u.s.a if you can buy only the upper heat roller.
Apr 14, 2008 | Office Equipment & Supplies
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
55 people viewed this question
k24674
jasbo
jasbo
