Question about Kenmore Freezers
Nothing on panel is working model cu-cr-w-lt 203c3938p001 what can be wrong.
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Jan 03, 2014 | Kenmore 31 cu. ft. French-Door Grab-N-Go...
I have an old Caravell CL200 which used to work ok. We haven't used it now for about 1yr and now trying to get it to go again. It just won't get cold enough what can be wrong?
What could be wrong:
compressor not running
freon leaked out
low on charged
txv plugged
dirty condenser
these are some of the things that could be wrong
hope this was helpful
Mar 27, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
Power signal light is flickering
If the unit is still working, and the power light is flickering, don't worry about it. I've seen this very often where the small, rectangular power light flickers and there is absolutely nothing wrong with the unit. It's just the light going bad. It will probably, eventually go out all together. Again, as long as it's working and keeping temp. don't worry.
Dec 30, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Only the top 2 freezer panels seem to be working. they have ice build up on them (it is not a frost-free model) and the other shelves have nothing. This is not usual. and the fruit i had in the bottom...
Good day,
You have a refrigerant leak. Unless the unit is under warranty(usually 5 years) the repairs would range from extremely expensive to impossible.
Recharging doesn't work, since the charge would simply leak back out.
Sorry for the bad news, but
Thank you for using FixYa.
Dec 19, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I have a 20 ft. Frigidaire upright freezer ab out 10 years old. Model #FFU2QF9FW1 and it will not stay cool enough so that items are about half thawed out. It takes it 3 days to freeze l/2 pint of water. I...
Sounds like it is not working properly to me. If not done already, clean out the radiator and air vents around the compressor to aid cooling.
All freezers and fridges are designed to work in a hot climate so ask if it needs the gas pressure increasing.
If it is gong to cost a lot, now may be the time to get a new more efficient one, it will save you money in the end.
Aug 09, 2017 | Frigidaire 20 cu. ft. / 566 liter Upright...
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmoew 4.8 cu ft 13.6 lt chest freezer
need more info model what type of frezeer
Nov 01, 2008 | Kenmore Freezers
Neff 3.8 cu ft freezer.
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Sep 10, 2008 | Neff 3.80 cu. ft. / 108 liter Upright...
Brand New Freezer, won't cool
You did nothing wrong. I believe it was faulty at the time of purchase. Return for refund
Oct 21, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezers Logo
494 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
