Question about Bose 3 2 1 GSX System
Ps321 subwoofer I have ps321 bose sub only can it be used for anything.rewired for powerd sub
  • 77 Answers
Yes you can wire it to anything but your going to loose power if the amp cannot handle it
Posted on Feb 24, 2009
How do I test the Bose ps28 3 sub woofer without any other bose components?
Thats a toughie because that system is well..a system. They build those so that each component runs through that main circuit board there and then thru the outs on the sub--I would look for a used player that you can hook it up to or pass on it.
Jan 24, 2015 | Bose Lifestyle Ps28 Iii Subwoofer Dual...
Klh s120eth subwoofer not producing sound.
Normaly C26 has turned bad. It's 22uF/25V and is easy to access when module is disassembled.
Dec 29, 2012 | KLH Audio Players & Recorders
Adding Subs to a Bose 901 system
The Bose system has sound that is unmatched, the 901 with the equalizer is amazing. I have done what you are thinking of doing, the speaker runs 5ohms giving more power to the coils, adding a sub will color the sound and will not give the desired results, the 901 equalizer may be damaged with the modification of the sub, not recommended.
Mar 06, 2012 | Bose 901 VI Main / Stereo Speaker
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
How do I wire the speakers to tuner and then to subwoofer?
depending on the subwoofer you have there are several ways to do this.
If you have an amplified subwoofer and a receiver with a sub out then just run a RCA cable from the sub out to the input on the sub. depending on the sub you may need a Y adapter to provide a signal to both the left and the right input.
if your sub has high level (speaker terminals) for inputs AND outputs you can use speaker wire from the receivers front speaker terminals to the sub and then from the sub to the speakers. You would use this same process if your sub does not have a built in amplifier.
Take note that if you do use the receivers subwoofer output its often necessary to turn that output on using the receivers on screen menu.
Hope that helps
Feb 12, 2010 | Bose Audio Players & Recorders
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
2008 Suburban LTZ with Bose Find Subwoofer wires 4 HiLow
It seems that your problem is actally the amp you are trying to use, many have either a switch or pontiameter to allow the speakers you are running either to play mid-range or low-range (sub) take a closer look at your amp that you are using
Apr 06, 2009 | 2008 Chevrolet Suburban
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
Bose 3 2 1 GSX System Logo
572 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
