Question about Maytag MLE2000 Front Load Stacked Washer / Dryer
Maytag mle2000ayw stops in mid cycle - Maytag MLE2000 Front Load Stacked Washer / Dryer
SOURCE: Stopped mid-cycle
I have the same problem.  Model: LAT2300AAE Serial: 30220055ZM
Maytag Performa - does anyone have any advise or should I just call the Maytag man?
Posted on Jun 22, 2008
Contronics
  • 20 Answers
SOURCE: Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
Posted on Jun 03, 2009
  • 220 Answers
SOURCE: Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Posted on Sep 03, 2009
  • 220 Answers
SOURCE: maytag MLE2000AYW not draining
When you removed that clog after the pump you should have gotten very very wet if that was the only clog.
 You will have to bail the water out of the tub or pull it out with a shop vac,and even then when you remove the other side of the hose on the pump you'll get a couple gallons of water coming at you,throw some towels over the motor control on the right front corner so it doesn't get wet and have more ready for the gush of water coming out.
 Throw rugs were notorious for clogging these hoses up also check the out going hose from the pump to the drain,if you have the heavy rubber hose run something through it to make sure it is cleared out.
 and if it was throw rugs your going to want to fill it and drain it several times when you get it draining again to make sure it is all cleared out of the machine,if it drains into a standpipe be careful it doesn't clog your pipes that stuff is like cement.
Posted on Sep 27, 2009
Testimonial: "Very helpful and a quick response. The advice was what was need to correct the problem. Also I appreciated the tips on what to expect."
SOURCE: dryer takes 2 or 3 cycles to dry clothes
dry turn very slow
Posted on Dec 03, 2009
How do we replace drive belt in maytag neptune dryer MLE2000AYW stacked unit? The dryer puts out heat but does not tumble....
Go to www.repairclinic.com and enter MLE2000AYW. You will be presented with a list of common replacement parts and may be able to view a generic video showing disassembly from which you can determine the belt installation procedure.
Aug 20, 2017 | Maytag Dryers
Maytag Neptune model MLE2000AYW. Why does it keep shutting down?
SORRY BUT UR QUESTION IS CONFUSING? U SAY IT SHUTS DOWNS THEN U SAY IT DOES NOT AGITATE? IF NO AGITATION I WOULD CHECK THE WATER PRESSURE SWITCH. UR DOOR SWITCH IS NOT LIKELY TO GO OFF AND ON, WHEN IT GOES BAD IT STOPS WORKING ALL TOGETHER. LESS U HAVE A BAD ACTUATOR? U CAN CHECK IT WITH A METER TO VERIFY , SEE PICS
AS FOR UR TIMER DOES IT ADVANCE ON ITS OWN? OR STICKING AND STOPPING AT A CERTAIN CYCLE?
May 27, 2015 | Maytag Washing Machines
Maytag Stack MLE2000AYW Washer Timer Won't Advance
If manually turning the timer allows it to spin and drain, then I would say the used timer installed was also defective. Try a new timer. You will save money if you get it online or go to an appliance parts store like "Mid-America Appliance" rather than Sears or the likes. Hope this helps.
Jul 06, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag performance series washer model mhwe500vp stops mid cycle
having the same problem found in side a small black hose with a small hole in it but have no idea what this hose is for. may be it is connected to some water sensor.
Jun 27, 2009 | Maytag Performa PAV2200
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Stopped mid-cycle
Jun 05, 2008 | Maytag Performa PAV2200
Maytag MLE2000 Front Load Stacked Washer / Dryer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
