Question about Garden
Door goes down to far - Garden
  • 520 Answers
There isnt a door on a chain saw
Posted on Nov 13, 2010
Sliding door
It may have a switch which engages when the door is fully open, if the switch is bad then the door would continue to try to open (too far)
Nov 01, 2013 | 2007 Honda Odyssey
Garage door
There should be two screw slots on the side/end of the lifter motor unit.
One is for how much force to close, the other how far down it comes.
Adjust the one for how far down it goes.
Jul 17, 2013 | Building Materials
Door closes all the way but then opens again
you can try adjusting the down force. what it sounds like when the hits the bottom the force sensor is saying there is an obstruction and is opening back up . just turn the down force adjustment higher on the logic board. if this isn't the problem you may have to adjust the down travel control, it maybe trying to force the door down to far and causing the force sensor to open door back up. if it is trying to force door to far in travel when the door goes down when it hit bottom you will notice the chain sag or the t bar will bend. good luck.
Sep 24, 2011 | Chamberlain Liftmaster Sears Or...
Liftmaster Professional Formula I, will not close.. Goes down and hits floor and open up again. Thank you
On the operator is a screw adjuster for how far down the door goes. Find this adjustment and rotate it in the direction of less travel. Then you may have to spend a few minutes setting it so the door closes snugly.
Gary
Aug 31, 2011 | liftmaster Chamberlain Garage Door Opener...
The garage door goes all the way down but then goes right back up - it does not close
Had similar problem. Re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Oct 22, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Door goes down but continues to bounce back up
If the door reverses when it hits the floor it is traveling too far in the down direction. Locate the 'down limit' adjustment on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will be necessary to get it just right.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears technical support for craftsman products- Will not work with car and remote. Goes down with internal contol, but goes right back up. Tried resetting it fro car and remote, with no results
Sounds like you have a couple problems. The remotes not working is probably the logic board. The door coming right back up is either the door sensors misaligned or the door is traveling too far and hitting the floor.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Granddughter stood on dishwasher door and now it goes down too far when opening. Spring assembly (pulley type) is FINE...but door goes so far down bottom shelf nearly breaks dishes when pulling out
This happens when people leave the door down, I've seen it many, many times, sometimes the door/hinge assembly can be replaced or even bent back, sometimes it totals out the unit...Good luck !
RMK...
Retired GE Factory Service
May 21, 2009 | Dishwashers
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
