Question about Dewalt 18V Angled Finish Nailer Kit
I have a Dewalt DC608 18 V 2 inch brad nailer. It worked fine for a couple of weeks. Now when I try to nail, I push it down and the guide lights come on and it sounds like a stipped sound, the light blinks 5 times. I can remove the battery and replace it, and it will do the same thing. I have bought a new battery because the trouble shooter manual says the battery is weak or dead. The new battery does the same thing even after I know it has a full charge. Any ideas? Thanks
5 Suggested Answers
  • 4 Answers
SOURCE: Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Posted on Feb 26, 2009
  • 1388 Answers
SOURCE: DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Posted on Jun 18, 2009
  • 21 Answers
SOURCE: I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Posted on Jun 13, 2010
  • 10865 Answers
SOURCE: My 18 gauge Dewalt Brad
Hi. Get an aerosol can of a penetrating lubricant called WD-40. Apply a few squirts to the action end of the nailer. let it sit for a couple of hours and then try it again. Repeat if necessary. J.
Posted on Aug 27, 2010
I have a DC608 cordless nailer that will not fire the driver the driver does not move at all but everything else seems to be functioning properly Thanks Tim
You can go to this webpage and download the owner's manual which gives instructions: http://servicenet.dewalt.com/Products/Detail?productNumber=DC608K
You can also download a parts diagram and order parts here.
I looked through the manual and found that DeWalt's Brad Nailer does not require tools to remove jammed nails from the nose piece. I believe this is the problem with your nailer, unless it's empty. Some of these nailers will not fire if there's less than 6 nails in them.
Another feature on this nailer is the trip lock. It is a safety feature that prevents accidental firing. Any time you adjustments made to the nailer will automatically turn the trip lock to lock position. You'll find this lock on the right side, under the Dewalt label.
The instruction manual will explain all this.
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | Dewalt DC608K 18 Gauge 2-inch Cordless...
I have difficulty with regular jams regardless of brad length. Thoughts?
Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
Mar 09, 2011 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Paslode 350 nailer wont work , push to fire fan works for 2 seconds then light flashes from green to red
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 17, 2011 | Dewalt D55141FNBN HeavyDuty 16Gauge Finish...
The gun will fire staples, nails do not set.
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
The business end should look like this:
Mar 07, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Exterior Galv. 6d cooler 2x .113 21 degree
This nailers are very inclusive , i have experience issues when i try other nails brands, and when i put DeWalt nails they work just fine. keep in mind that most nailers have a safety that when a couple of nails are in the magazine it wont shoot,
Apr 02, 2009 | Dewalt D51844 Framing Nailer
Nailer jams with 1-5/8 brads
It sound to me that the 1 5/8 brads are not 18 guage but probably 16 guage and they will not work. Double check them first before going any further. You can usually lay them next to the smaller ones that work and see the size difference, if not let me know and I will dig deeper.
Feb 21, 2009 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Dewalt 18V Angled Finish Nailer Kit Logo
203 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
