Question about Bissell 6594 PowerForce Bagless Upright Vacuum
My bissell 6596 motor running hot, therefore keep breaking belt, what should i do.
reddevil6
  • 1673 Answers
SOURCE: bissel upright vaccum model 6594
Did you check the inlet hose down by the brush roll, it may be clogged there. Your system says that that must be a clog. Did you drop something like a big marble down thru the hose and have go all the way thru?
Posted on Feb 14, 2008
reddevil6
  • 1673 Answers
SOURCE: Replacement parts...
Most likely it is the top cover that needs to be replaced, part #2031238 and is around $30. It would have that guide on it.
Posted on May 26, 2008
  • 107 Answers
SOURCE: Bissell 6596 bagless turbo - minimal suction & burning smell
You can reach the motor, however your motor is no longer in operable condition. This is what you hear when you turn it on. You must replace the motor for this to go away. Below is the motor part number if you would like to replace it. It will cost you about half the amount of the unit to replace.
Motor # 2032211
Posted on Dec 19, 2008
  • 164 Answers
SOURCE: Unit wont turn on.
might be the switch is bad ore lose connection for the wire came off the plug
Posted on Jul 25, 2009
  • 694 Answers
SOURCE: The belt on my vacuum
I would guess you aren't centering the belt correctly, thus it's edge is caught between the brush and another solid object, causing the breakage.
When you get the belt on the the brush and the brush back in place, turn the brush a few times by hand to make sure it's not catching on anything. After you get the powerhead put back together, do this again. It's a common problem if the powerhead isn't assembled correctly.
Here's a video clip from the Bissell site demonstrating changing the belt.
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
Posted on Jan 09, 2011
Bissell pro 2 brushes dont turn, belts are fine , shaft turns fine. how do i check the motor that turns these parts
You should be able to hear the motor running when it is switched on. If it doesn't make a noise then it isn't running and needs checking. If it does run be aware the drive belts can appear ok but sometimes considerably lose elasticity. so they won't drive. A new belt is often half the length and must be stretched to fit.
If the motor doesn't run and it is a corded vacuum it must be checked through with care. An internal break in the power cord is the most common cause of trouble with a faulty switch number two on my list and a faulty thermal breaker also in the top ten.
In the case of a cordless, first check the charger...
Dec 31, 2016 | Bissell Vacuums
My Bissel powerforce 6596 has suction but the dirt is not making it into the dirt cup. If I shut it off, the dirt drops to the floor. Also the motor seems to be over heating. All filters are clean. I...
Just because you cant see the obstruction doesnt mean theres not one. The hose could be stopped up somewhere not visible to your eyes. I have one and I have to take hose off and apart to clean it out. check the roller. Is it rolling?
May 17, 2011 | Bissell 6594 PowerForce Bagless Upright...
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
The belt on my vacuum cleaner model 6596 bissel powerforce bagless turbo keeps breaking. As soon as I put on a new belt and start it up the belt snaps. It is the durabelt meant for this vacuum model....
Jan 08, 2011 | Bissell 6596 Bagless Upright Vacuum
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
Unit wont turn on.
Jul 23, 2009 | Bissell 6594 PowerForce Bagless Upright...
Motor # 2032211
Dec 19, 2008 | Bissell 6594 PowerForce Bagless Upright...
May 26, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
64 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
