Create a directory named WORKING at the root of the (Activities Disk) (h drive) and then move the LEVEL-1 directory and all of its contents into the \WORKING directory. (this must be done at the command line in xp)
  • 2,296 Answers
Here is the code that you have to put in the command line:
md h:\WORKING
xcopy h:\LEVEL-1 h:\WORKING
Posted on Nov 15, 2010
Sony sdcard root directory is full
There is a limit to the number of files you can copy to
the root directory of a memory card. The simple solution is to create folders for the photos...
then you can take full advantage of the memory capacity.
to make a folder right click in the drive select new folder you should name it
hope it helps
May 31, 2012 | Electronics - Others
I installed a second WD My Book, after the first one inexplicably filled up too quickly. Now the second one has inexplicably filled up also. What could be causing this?
The most logical reason for this problem to occur is because you're storing too many files in the ROOT of the external hard disk drive (HDD). The Windows file system can only manage a limited number of files (about 500) in the root of ANY drive. It is better to store those files in a FOLDER on the drive; Windows can manage an infinite number of files IF you store them inside a folder. Let's see if we can resolve this step-by-step:
1. Open Windows Explorer and navigate to the external HDD (drive E:, drive F:, drive G:,or whatever letter it has on your system).
2. If the external HDD does NOT have a name (such as "WDMyBook01", or something else easy to remember), RIGHT-CLICK the letter of the external HDD; Windows will give you the option of creating a NAME for the external HDD.
3. Create a name for the external HDD, you can use any combination of letters or numbers, but NOT MORE than 11 characters in length. By creating a distinct name for your external HDD, you'll have an easier time remembering which MyBook drive has certain files on it. Be sure to do this for BOTH external HDDs.
4. Next, create a new folder in the ROOT of the external HDD; give it a simple SHORT name, such as "Folder01" (no quotes).
5. MOVE ALL OF YOUR FILES from the ROOT of the external HDD into the new folder you just created.
6. In the future, put ALL your files into a folder on the external HDD, so you can avoid experiencing this problem again.
7. As you've probably already guessed, it is also a good idea to avoid putting more than 500 files into the root of ANY HDD. SOME files MUST be stored in the root, because that is where Windows expects to see them, but don't add any of YOUR files, the ones you create or download, into the root of the drive.
8. This numerical limit also applies to USB flash drives and other storage devices. You avoid this problem the same way, by creating folders in the root of the drive and storing all files inside a folder.
Good luck with this; let us know if you have any questions.
Apr 26, 2011 | Western Digital My Book Essential 1TB...
I want to install arcsoft totalmedia back & record on my computer. The directions say to go to the root directory on your simmpledrive external disk drive and double click setup.exe to launch the...
The root drive is always the drive letter with nothing after it.
If your external drive is drive E, then the root is E:\.
You can see this in Windows explorer.
1. Right click on the My Computer icon on the desktop.
OR
Right click on the Computer name in the list of components to the right of the program list (Windows 7, Vista)
OR
Click Start, run, type the word explorer and click OK.
2. Look for the drive letter that says "simpledrive"
3. Click on the drive letter and look for setup.exe
I hope this helps.
Jan 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Jensen MP3 Capacity issue
As the root directory is already full, you will first need to move or delete some files from your root directory before creating new folders in the root directory.
Hope it helps. Let me know how you go.
Jan 02, 2010 | Jensen Audio Players & Recorders
Automatic updates won't work
First, access the "Windows Update" service and stop it at "Start-Run-type 'services.msc'.. Next, create a new directory "C:\Windows\SoftwareDistribution.old", then move the
contents of "C:\Windows\SoftwareDistribution" into that folder (cut &
paste), and then trying "Windows update" again. Running Windows Update should create new, uncorrupted contents for the directory.
(Sometimes it's easier to rename the "SoftwareDistribution" folder to "SoftwareDistribution.old", then create a new one with the same name in the same C:\Windows location.)
Nov 21, 2009 | Computers & Internet
Floppy program, no floppy drive.
get an external usb foppy drive
Sep 22, 2009 | Computers & Internet
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
DNS
DNS is the primary name resolution service for Windows Server 2003. Active Directory depends on DNS for domain controller location, and DNS influences Active Directory domain naming. Thus, to fully understand Active Directory, it helps to understand how DNS acts as an integral component in the design of Active Directory.
DNS provides Active Directory with both a name resolution service for domain controller location and a hierarchical design that Active Directory leverages to provide a naming convention that can reflect organizational structure.
Typically, a DNS domain namespace deployed to accommodate the Active Directory mirrors the Active Directory domain namespace. In cases where there is an existing DNS namespace prior to Active Directory deployment, the DNS namespace is typically partitioned for Active Directory, and a DNS subdomain and delegation for the Active Directory forest root is created. Additional DNS domain names are then added for each Active Directory child domain.
DNS data is used to support the location of Active Directory domain controllers also. During or after the creation of the DNS zones used to support Active Directory domains, the zones are populated with DNS resource records that enable network hosts and services to locate Active Directory domain controllers.
PS: As sourced from Microsoft Technet Site
Jul 24, 2008 | Microsoft Windows Server Standard 2003 for...
Active directory
An application directory partition is represented by a domainDNS object with an instanceType attribute value of DS_INSTANCETYPE_IS_NC_HEAD combined with DS_INSTANCETYPE_NC_IS_WRITEABLE. This domainDNS object represents the application directory partition root (NC head), and is named similar to a regular domain partition, for example, "DC=dynamicdata,DC=fabrikam,DC=com", which corresponds to a DNS name of "dynamicdata.fabrikam.com". An application directory partition can, therefore, be instantiated anywhere a domain partition can be instantiated. There is no NetBIOS name associated with an application directory partition.
It is possible to nest application directory partitions, that is, an application directory partition can have child application directory partitions. Searches with subtree scope rooted at an application directory partition head will generate continuation references to the child application directory partitions.
An application directory partition replica can only be created on a domain controller that is running on Windows Server 2003 and later and only while the Domain-Naming FSMO role is held by a Windows Server 2003 and later domain controller. In a mixed forest that has both Windows Server 2003 domain controllers and down-level domain controllers (Windows 2000 domain controllers or Windows NT 4.0 primary domain controllers), an attempt to create an application directory partition replica on a down-level domain controller will fail.
An application directory partition also has a corresponding crossRef object in the Partitions container of the configuration partition. The crossRef can be pre-created manually before creating the domainDNS object. The pre-created crossRef object must have the attribute values shown in the following table or the partition creation will fail. If the crossRef object does not exist, the Active Directory server will create one when the application directory partition is created.
Jul 09, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
