Question about Suttle 1 Outdoor POTS Splitter (SE649A1)
I am trying to find the wiring diagram for the Suttle ADSL Outdoor DSL Pots Splitter (Model # 649A1)
What cable do i need?
You should give more detailed information!
If I understand correctly, you have an ADSL over a normal landline with a splitter between the phone and the modem. If you now want to move the modem you need a simple telephone-cable with at least two wires.
May 29, 2014 | D-Link Sky Wireless Adsl Broadband Modem...
Zoom X7n Dsl 2/2 Modem/router/gw dsl light blinks constantly when trying to connect to Earthlink
Try removing the splitter, if it works then you might have a faulty splitter and you need to get it replaced. You might check if you are using the first phone jack in your house / apartment. I remember that was key when i was on DSL. Hope you get it sorted out, not having a working connection is very annoying.
Nov 18, 2013 | Zoom X7n Dsl 2/2 Modem/router/gw
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Filter connection
Hello, DSL Filters, or Microfilters as they are often described, are required to separate the
normal low-end frequencies associated with voice calls from the high-end frequencies
used by your ADSL connection. The correct installation of these filters is important to
ensure the best possible performance of your ADSL connection.
Introducing the DSL Filter:
The diagram below illustrates one example of an ADSL Filter. There are several
different varieties - including the dongle-type below, a splitter, which plugs directly
into your wall socket, and a plate, which replaces the standard BT Master Socket.
Email me on : cirocpatel@gmail.com for more info
Please let me know if you have any further questions or concerns.
Thanks.
May 02, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
When my phone rings the kids get booted off xbox live and i have wireless internet and wireless adapter for xbox360
Hi Jeannie,
Based on your problem I assume that you have DSL. When you get hooked up for DSL they send filters that you are supposed to put between EVERY phone and the jack. (Don't forget phone lines for satellite and alarm systems).
If your dsl drops every time the phone rings, there are usually 2 things that cause this.
1) A bad filter in your house. If a filter is bad or missing it can cause the dsl to drop either when the phone rings or if someone picks up the phone with the bad filter.
2) The other reason could be on your ISP's side. It's called a POTS splitter. You have one of these if you have BOTH phone and DSL. It's what sort of combines the 2 together. There are a number of problems that can occur with a bad pots splitter. i.e. DSL works - phone totally dead, Phone works-dsl - totally dead, disconnects, etc...
I suggest that you hook up the dsl modem by itself. DISCONNECT ALL PHONES IN THE HOUSE. Do NOT have anything connected at all except the dsl modem. No filters, phones, directv, digital cable, or anything else in a phone jack. Then when you are up and surfing, take your cell phone and call your house. Technically it should just ring and ring. Unless you have voice mail in which case it will go to voice mail after so many rings. Anyway, see if when the line is ringing in your cell phone if it is dropping you off. If it DOESN'T, then it's probably one of the filters, jacks, or wiring. If it still disconnects, it's probably the POTS splitter with your ISP.
Good luck and if this helped please help me out and leave feedback!
Thanks!
Feb 08, 2010 | Computers & Internet
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
Do you have a zyxel series p600, 660R-D1 dsl modem user manual? I have one and have a range of kbps of 3050 to 240 kblps. I thought I would read and see what to expect, Earthlink and the phone company...
The user manual or user guide of the 660R-D1 is available on the zyxel.com site, if you go into the following path:
Support and downloads --> download library ---> up at the right hand side top you see a drop down menu with list of products, choose 660R Compact series. This brings you to the download page and you can choose out
Model :
P-660R-D1
Version : 3.40
Language : English
OS : N/A
Release Date : 07-14-2006
Citating the part from the manual that I think is important (see down at the bottom of this post the speeds, and the note that it may be influenced by your ISP standard. Ask your ISP what they use.):
1.1
The ZyXEL Device is an ADSL2+ gateway that allows super-fast internet access over analog (POTS) or digital (ISDN) telephone lines (depending on your model).
In the ZyXEL Device product name, "R" denotes an integrated router and "D" denotes a chip set standard.
Your ZyXEL Device product name ends with a number. Models ending in "1", for example P660R-D1, a denote a device that works over the analog telephone system, POTS (plain old telephone service). Models ending in "3" denote a device that works over ISDN (Integrated Services Digital Network). Models ending in "7" denote a device that works over T-ISDN (UR-2)
1.2
The DSL RJ-11 (ADSL over POTS models) or RJ-45 (ADSL over ISDN models) connects to your ADSL-enabled telephone line. The ZyXEL Device is compatible with the ADSL/ADSL2/ADSL2+ standards. Maximum data rates attainable for each standard are shown in the next table:
ADSL:
Up: 832 kbps Down: 8Mbps
ADSL2:
Up: 3,5Mpbs Down: 12Mpbs
ADSL2+:
Up: 3,5Mbps Down: 24Mbps
Note: if your ZyXEL Device does not support Annex M, the max ADSL2/2+ upstream data rate is 1,2Mbps.
ZyXEL Devices which work over ISDN do not support Annex M. The standard your ISP supports determines the maximum upstream and downstream speeds attainable. Actual speeds attained also depend on the distance from your ISP, line quality etc.
Please let me know if the above answered your question:)
Jan 26, 2009 | Computers & Internet
Adsl2+
don't go for the cd you configure your self abd it think that your dsl not get the perfect dsl link
Jul 10, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Suttle 1 Outdoor POTS Splitter (SE649A1) Logo
221 people viewed this question
Top Suttle Computers & Internet Experts
David Payne
David Payne
Are you a Suttle Computer and Internet Expert? Answer questions, earn points and help others
