Question about Panasonic CQ-DF66 CD Changer
What are the specifications for the panasonic df66 stereo? I am looking to get some speakers and need to know what to get.
Panasonic mash
Usually if something is shutting down as the volume is turned up, it is caused by a bad speaker. Try disconnecting one speaker at a time, and see if you can turn up the remaining speakers until you find the one that is causing the problem.
May 29, 2013 | Audio Players & Recorders
I want to connect my Panasonic SL-SV570 to my car radio/tape player and have the sound come through the radio speakers. What device do I need to purchase?
You need a cable. Look for the Male RCA/stereo jack dongle/cable so you can connect the stereo jack to the discman and the RCA (male) to the back of your car stereo.
There should be 2 female RCA jacks hanging at the back of the stereo (White and Red).
Jun 05, 2010 | Car Audio & Video
I want to install in my car a panasonic car stereo AM/FM/CD player CQ-EN9680TA, i dont know the wiring code of the terminal (power and speakers connections), can you help me pls? thank you
Hello marlomeneses,
Wiring color codes are different for different makes and models. Go here and select your vehicle for the color code: www.modifiedlife.com
The best way is to purchase a vehicle specific wiring harness that plugs directly into your car wiring. Splice the wires from the harness that came with your new Panasonic to the vehicle specific harness and plug them in.
Here's an example of such a harness made by Scosche. This one fits 2002 and newer Chrysler/Jeep vehicles. There's a harness for most all vehicles. Local car audio shops, Best Buy, and even WalMart sell such harnesses.
http://www.sonicelectronix.com/item_1669_Scosche+CR02B+-+CR02.html
Hope this helps.
Oct 06, 2009 | Panasonic Car Audio & Video
Stereo wire color > front doors speakers
Try this link.
http://www.the12volt.com/installbay/stereodetail/1412.html
Aug 16, 2009 | JVC Car Audio & Video
House already wired up for wall speakers (2 wires) BUT
Hi...
The 4 wires are 2 for the treble/midrange 2 for the bass.
You can tie the wires in parallel ( one wire from one pair to another in the other pair and repeat) but you need to know how many "ohms" the stereo can handle.
Should say on the back of the rack system
Jan 12, 2009 | Panasonic SC-AK500 CD Shelf System
I need a diagram for the radio to install my new system please, just need to know what the wire colors are so i dont have to spend 2 hours of test to find them myself. I will find them but if you can let...
For 2008 Honda Civic, it would be as shown below. For all other years, you may want to try looking for your specific year here where the information was originally posted.
2008 Honda Civic Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: White
Car Radio Accessory Switched 12v+ Wire: Violet
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Light Blue
Car Stereo Amplifier Location: Located in the front of the center console under the center of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green
Left Front Speaker Negative Wire (-): Pink
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Orange
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 31, 2008 | Honda Civic Cars & Trucks
Car stereo wiring diagram
Only Wharfedale that I found was a UK company for loudspeakers. Sorry, but you need to me a little more specific with your request.
Chris
May 27, 2008 | Car Audio & Video
I have the factory wiring plug for my panasonic DF600U car cd&stereo and the front and rear speaker wire's are in it. But the power wire's are not.I have added the missing wire's but I do not know...
Car stereo need only POSITIVE & NEGATIVE wirings look the ground sign for negative, mostly body ground or negative supply. Then trace the positive line mostly series a fuse and fuse holder.
Apr 29, 2008 | Car Audio & Video
Having problems fitting Panasonic CQ-C1323NW car stereo into Ford Fiesta
YOU SHOULD HAVE TWO LEADS IN THE CAR, ONE FOR POWER AND ONE FOR SPEAKERS, YOU WILL NEED A FORD TO ISO ADAPTOR LEAD AND THEN YOU WILL NEED THE LEAD WHICH CONNECTS TO THE PANASONIC RADIO
Dec 05, 2007 | Car Audio & Video
Car Audio & Video Logo
54 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
