Question about Texas Instruments TI-84 Plus Calculator
My calculator suddenly won't turn on anymore and the batteries are fine. I think that someone messed up my calculator so that it won't turn on.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Posted on Nov 12, 2010
Suddenly not turning on anymore
does it turn on with charger pluged in if so needs new battery
Jul 13, 2012 | Samsung Galaxy Tab Tablet PC
Someone messed with my calculator yesterday and today it highlights the word busy. I can't get it to work.
Best is to remove the batteries for a while, which should reset the memory and default to the factory settings once you place them back in and power it on.
Dec 08, 2010 | Texas Instruments TI-89 Calculator
Calculator will not turn on. Batteries are good.
Hi
with this model you need to change the all keypad it one unit and canot be open and fixed
the price for a Keypad is $40 no new keypad only used no more new parts for this model
ecrdn@yahoo.com
Jack
May 03, 2010 | HP 48G Graphic Calculator
It will not turn on
I suggest you read the article
What troubleshooting can I try if the TI graphing calculator will not turn on?
It contains internal links to other parts of the TI Knowledge Base.
Hope it helps.
Nov 12, 2009 | Texas Instruments TI-Nspire Graphic...
Does not turn on anymore
The battery does run out. If you go to a CVS, or a Longs or something like that you can get a replacement battery (and some of them even replace it for you).
I think you need to replace your battery (unless your on button feels funny when you press it, but a drained battery is more likely).
Sep 29, 2009 | Texas Instruments TI-30XA Calculator
I recently had my car broken into and someone tried to steal my system. Thankfully my fiance heard and went out in time and they drove away. They had disconnected some of my wires and we tried to put them...
wire from battery(normally red) to 12v+, really skinny wire(normally blue) to remote, black or silver wire from ground to grnd. No you dont need the converter as long as you have your rca from asftermarket cd player to your amp(preferred way). You might have also bridged your amp with your speaker wires which would cause your system to run on a different ohm which would cause the bass to get louder then overheat you amp which would turn it off.
Aug 16, 2009 | Rockford Fosgate Car Audio & Video
TI- 83 Plus Silver Edition problem
Many TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 29, 2008 | Texas Instruments TI-83 Plus Calculator
My Ti83 silver edition will not turn on.
I'm not sure if this will help you patchesb7; it sounds like your calculator is having issues :(
This will help others whose calculators suddenly won't turn on anymore, even after changing the batteries.
Note:
This will return the calculator to the way it was when you got it out of the package. Any data or programs have stored since will be lost.
Step 1: Remove all four AAA batteries.
Note: You will have to hold down the CLEAR button while doing Steps 2 and 3. Do not let go until after you have pushed ON in Step 3. I found this easiest to do by holding the calculator upside in my left hand with my pointer finger holding the CLEAR button so the ON button was easier to access.
Step 2: Hold down the CLEAR button (located under the arrow keys) and reinstall the AAA batteries.
Step 3: Press ON button and then let go of both buttons. The screen should say the RAM has been cleared. Press CLEAR to continue.
Aug 24, 2008 | Texas Instruments TI-83 Plus Calculator
My HP won't turn on anymore
I just fixed two "failure to power on" 49g+'s. For the first one I did a moderate slap of the unit against my thigh and then tried a reset (I thought maybe the reset was jammed with some debris) - it worked! The second one just needed me to scrape off some corrosion (an old toothbrush works) from the battery terminals - AJ
Jun 24, 2006 | HP 49g+ Calculator
Texas Instruments TI-84 Plus Calculator Logo
23 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
