Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I'm installing a garbage disposal. I've got everything done and I'm installing the switch. When I got the switch installed and tried to turn it on it tripped the breaker. When I bypass the switch it works fine. Originally I tried a 15 amp switch. Tried switching to a 20 amp switch (even though the disposal is only 6.5 amp), but have the same problem. Any ideas?
  • erik_lilly Nov 12, 2010
    No. I used the common connector for the black and put one white on each side originally. However I tried re-wiring it as suggested, but it still trips the breaker.
    No I had connected it with the black wires going to the common connector and one white wire to the in and the other to the out. Tried re-wiring as suggested, but still trips the breaker.
    Genius:
  • 1,015 Answers
When you are wireing switch are you hooking black wire on incoming side of switch then out going black wire on leaving side,with white wire wire nutted together in switch box. If not try it that way and it should work. Hope this helps you.Thanks
Posted on Nov 12, 2010
    Tried re-wiring the way you said. Still trips the breaker.
  • Jack Spooner Nov 12, 2010
    I Should have suggested that you try new switch as the first. one probably burnt out if you went black on one side and white on the other. Sorry I was not clearer on that. Thanks
Frigidaire grind pro 3\4 hp
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Replace disposal?
Call about warranty.
Buy another identical one and return defect in new box.
Gene
Nov 30, 2013 | Frigidaire Garbage Disposals
When disposal turn on it flips the broker
The motor might have a short because disposal has rusted out and water is getting into disposal. Or the switch might have short.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#leak
Check switch for signs of burning and high heat. Replace switch. Replace disposal.
May 13, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal hums, but doesn't work. blades turn freely, as well asthe motor with a wrench- with no pressure?
Copy following link for disposal troubleshoot, and replacement tips:
Sounds like disposal motor has overheated and shorted.
Fortunately today's disposals are fully contained, and did not cause fire.
Replace disposal.
Mar 16, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a brand new garbage disposer and was surprised that it was so quiet. I've been in homes with a disposer and they are noisy and the water and scraps get sucked down the drain quickly, but m
You're complaining that the garbage disposal is working quietly?
Most folks complain the opposite.
Look down opening and see if blade is spinning rapidly.
Check that disposal eats lettuce leaves and carrots.
Otherwise you have good disposal.
Nov 21, 2012 | Badger 5 All Insinkerator 76037h 1/2 Hp...
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
107 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
