Question about Belkin (F5D7230-4) Router (587009)
I am trying to fined my wep key on my rooter - Belkin (F5D7230-4) Router (587009)
  • 1,679 Answers
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
*Dont forget to rate this solution and provide comment
Posted on Nov 12, 2010
LAN connectivity problems
reset the rooter small button on back a pencil point will do about 3 sec and release the new wep key on back of rooter
Apr 03, 2013 | Computers & Internet
How can I change wireless password?
from your rooter administration program/file.
you need to log in into ur rooter. Ussually in a browser : http://192.168.1.0 or 192.168.1.1 or 192.168.0.0 or 192.168.0.1
Login in there with ur custom username and password (you should have them on ur rooter manual. (try user: admin and password: admin it should work.)
May 02, 2011 | Computers & Internet
Have bought a new t v {panasonic viera} also bought a wireless LANadaptor to link up with my rooter for internet accessbut keeps asking for encryption key
Ken,
You need to use the same encryption key that you provided when you connect any other wireless device to your wireless network. If you have never set up any device to connect wirelessly, you should do so now. On page 12 & 13 of the manual, you'll find detailed instructions on how to set up and more importantly, secure your wireless network with a 64 or 128 bit WEP key. Once you have logged in and see the screen shown on the bottom of page 12, do NOT click on "Run Wizard". Instead, simply click the "Wireless" button. Make sure you make note of the SSID (or change the SSID) and enter a new WEP encryption key (do not leave the keys unchanged or blank!) before navigating away from this page. If you choose a 64 bit key, you can provide a 10 "string" consisting of digits 0 - 9 and a - f. I like to use a telephone number because they are the correct length and there are plenty I know "in my head" and never forget them. You can pick whatever you like. You might want to write this info on a piece of paper and tape to the router for easy reference later. You should not change any other values in the router's settings or you may not be able to connect to the internet.
If you have previously set up other devices to connect to the router wirelessly, you'll have to update them with the new WEP key and SSID (if you changed it).
Read page 30 of the manual to learn how to change the Username and Password from the default settings.
That's it. I hope this helps & good luck. Please rate my reply. Thank you.
Apr 05, 2011 | D-Link AirPlus DI-524 Wireless Router
Keep having to enter the wep key to start ps3 then it times out saying the key is incorrect ? Recently changed from AOL to BT and console was working fine but now no service
Can I just ask, are you entering your AOL WEP key or your new BT WEP key? Just in case you didnt know your BT router will have its WEP key on a sticker on the back of the router. You need to go into network settings --> internet settings and change the WEP key that is registered to the system. It should then connect with no problem.
Hope this helps.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
WEP wrong length
That means the type of security key you are selecting is different with the type on Router. Change the type like WEP.WPA, WPA-2 and try entering the same key.
May 27, 2010 | Intel Computers & Internet
I entered a WEP encryption key onto my Dell TrueMobile 2300 router, but when I try to connect to it wirelessly (and put in the correct key), I don't get any connection to the internet. It works fine when...
Dear Friend,
You must be trying the WEP -OPEN.
try WPA-PSK and put in your customized password.
Before making any changes in the system remove all the cables from the router and reset the router once and try to configure the network with WPA- PSK.
It should work.
If negative plz contact your ISP
Thank You
Prasanth83
May 11, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I have just purchased a belkin cable rooter n+wirless rooter, I have two questions 1 - Set up secruity word router attached to wired pc. wirless lap top can connect but does not ask for password. why is...
1. Belkin makes you not only setup the wireless/WEP but you have to turn it on as well. (radio button I think) Some also have a separate configuration for N vs. B/G, since it does both. check your setup
Look under "Wi-Fi Protected Setup" in the configuration.
2. This is normal, that's your power light.
Dec 09, 2009 | Computers & Internet
No WEP capabilities...
WEP encryption is not very safe and will be less in use in the future. Anyway, you have to determine, if WEP 64 bit or WEP 128 bit is used (26 digits), mostly it is set to 128 bit.
If the connection fails, try to input the key with WZC (Windows Zero Configuration) instead via the interface-software from the manufacturer. If the service WZC is started (important!), you have a tab in the properties of the adapter to make the configuration with conf.less win connection, you only have to put in the right key.
Gr
Phalanx41+
Aug 17, 2008 | Airlink (AWLH4130) 802.11g/b Wireless...
Cannot connect to network with WEP key encryption
It will not connect to a wireless network with WEP. it supports only the latest encryption. Try changing the encreption on your router to WPA or WPA2
Mar 17, 2008 | Archos 605 Digital Media Player
Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Dec 02, 2007 | Archos 604 Digital Media Player
Belkin (F5D7230-4) Router (587009) Logo
46 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
