Question about IBM NetVista A40 PC Desktop
IBM Netvista PCI/PNP Slot 3 Error
Hello, I was told that my NIC card was bad in my IBM Netvista (runs XP) so I went out and bought a new one to install. I shut down, installed the new NIC card (I left the old one in since it didn't look like I'd be able to remove it). When I turned on the PC I got 'Resource Conflict' errors saying 'PCI in slot 3, PCI serial bus controller in slot 3'...then it would say no boot filename received and no OS found. I can't get past the Boot Agent since it keeps failing. I tried shutting down and removing the new NIC card and when I reboot I still get the same errors. Any idea what could be causing this and how I can fix it? Thanks!
  • Anonymous Nov 15, 2008
    I have the same issue when I insert any of PCI cards, for example, BEHOLDER TV tuner or any of Network NIC cards. I spent plenty of time searching in google and lenovo pages for some explanation and manuals how to configure manualy IRQ in IBM NetVista, but gues what?, nothing is about this BRAND at all. Please help if u have some work arround this conflict.
I had to remove the old network card and replace it with a new one to resolve the issue.
Posted on Dec 09, 2008
How many extra usb circuits are there on my ibm 09k9982-011 mother board
IBM 09k9982 011 ATX MOTHERBOARD P3 11s19k5609z 1N0Z9131W3C Netvista Socket 370
Condition: Used - pulled - working
Content: 1 Motherboard only
Compatible part # 06P2525 01
FRU 09K9982 , 89P8010
Chipset Intel 815 - FSB 100/133 - 2x Dimm PC100/PC133 - Agp 4x - 3 PCI - 2 USB
IBM 09K9982 Netvista Pentium III Moederbord.
Socket 370 Mini-ATX.
Intel 815 chipset.
2x Dimm pc-100/pc-133
Agp-slot (4x)
3x PCI
2x USB
Sound and Video on-board.
To use with : FOR IBM Netvista Socket 370 , 6648-TAU
hope this helps
Dec 11, 2010 | IBM (09N5424) Motherboard
Just installed xp for a friend on an old ibm netvista 6794 NZU pc. Went to ibm website but can not find the motherboard or chipset drivers to allow this pc to acess the internet. Can anyone help please. ...
It's a big pain when you dont have the right driver. but try this:
1. download and install the Windows Service Pack 3 (XP SP 3) in the computer and check if it works.
and how are you trying to connect to the internet? you might just want to put in an extra PCI network card, if you want to use the broadband or if you need the usb ports to work, try a PCI USB card instead.
either ways, make sure you have installed SP3 in that computer.
Nov 17, 2010 | Computers & Internet
What kind of mobo does this Toshiba V3100 desktop machine have? And what kind of NIC do I need? Besides the origanal RJ 11 NIC that came w/it?
Here is a pdf file showing the specs of your computer:
The MB is a micro ATX board with 3 PCI expansion slots. The one slot appears to have had a NIC card to which you refer. You would have to obtain a PCI Ethernet card (NIC).
Thanks for using Fixya.
Oct 01, 2009 | Toshiba V3100 Plus PC Desktop
Ibm netvista 2257-32u
First off I would troubleshoot the NIC onboard, but if it is not working then you should have an available PCI slot to install a new NIC. However you will also have to disable the onboard NIC in the BIOS.
If you are using windows
Click --Start --run-- type in cmd and hit <enter> (this will bring up the dos box)
then type ipconfig /all
It should come back and show:
Connetion-specific DNS Suffix :
Description: Brand and type of NIC
Physical Address : xx-xx-xx-xx-xx-xx
DHCP Enabled: yes or no
AutoConfiguration Enabled: yes or no
IP Address:
Subnet mask:
Lease Obtained: date when it connected
Lease Expires: date when connection expires
Default Gateway:
DHCP Servers:
DNS Servers:
If all this is showing correct then try typing ping this will be the NIC itself and it should reply back. If not then do the following.
If it does not show up then check device manager and see if the NIC is disabled.
if it is disabled try reenabling it.
if it is not unistall the device and then reboot the PC it should find the NIC and install it.
if all this fails then replace the NIC
Oct 30, 2008 | IBM Computers & Internet
Installing AGP card
Try it with the cover off first. Just don't stick your fingers in there anywhere. ;)
Sep 28, 2008 | IBM Netvista Intel Pentium 4 2.4GHz /...
Netvista 8306 NIC driver
There you go the driver you need should be at the top of the list.
Thanks and enjoy. please don't forget to rate.
If you need any further assistance please ask me.
Jun 18, 2008 | IBM NetVista PC Desktop
USB 2 PCI card installation on IBM NetVista with MS Vista
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Apr 28, 2008 | IBM NetVista A40 PC Desktop
2 ethernet cards can't work together
If in your network you are connecting computers directly to a PC thru multiple nics and not a router or hub leaving one as server and the others as clients and that server is NT 4,0
NT 4,0 can not auto configure the cat5 cable and would need at least 1 cable to be a cross-over and not a patch.
Apr 01, 2008 | IBM NetVista A40 PC Desktop
Vga driver
Hello...maybe you can go to the control panel and use the "add new hardware" function and see if your windows support your screen...than you can use pnp or manual can select from a list... and in some cases it is better with a "generic" driver than none at all...i use my screen as pnp and it isn't.pnp ..under ok...don't forget to have your windows cd at hand ..yo may need it...plase tell me how it went...good luck...Ron
Mar 08, 2008 | IBM NetVista M41 PC Desktop
PC Card
There is a bunch of "model" numbers for the IBM netvista PC. You didn't menton yours in your question but after looking at a dozen or so I'll bet you have at least one PCI slot free for a wireless PCI card.
Jan 02, 2008 | IBM NetVista PC Desktop
IBM NetVista A40 PC Desktop Logo
700 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
