Question about Brother MFC-8460N All-In-One Printer
What do I enter when it asks for a host address when scanning to FTP?
  • 385 Answers
The host address is your computers ip address!!Good Luck!
Posted on Nov 12, 2010
How do i enter service mode
Use DHCP : Off Use BOOTP : Off Use RARP : Off Enable DNS Dynamic Update : On Use Zeroconf Function : On IP Address : 192.168.1.20 Subnet Mask : 255.255.255.0 Gateway Address : 192.168.1.1 LPD Printing : On IPP Printing : On IPP Printer URI : printer RAW Printing : On Raw Port Number : 9100 RAW Mode Bi-direction : Off FTP Printing : On Primary DNS Server Address : 0.0.0.0 Secondary DNS Server Address : 0.0.0.0 DNS Host Name : NB-17FB0000859B9287 DNS Domain Name : Multicast DNS Service Name : Canon iPF710 (9B9287)
Nov 21, 2012 | Canon imagePROGRAF IPF605 Printer
SMB Scanning - Virtual Server envirnoment
A quick fix for that would be to enter the fix IP adress instead of the host name, or to check if the host name on the SMB server is correct, and reboot the SMB server.
A good help is to do that from another PC to check if that works:
ping the IP adress try to connect to smb://IP_adress_or_hostname
If that works on the PC, there's no reason that it shouldn't work for the scan
Jul 03, 2009 | Konica Minolta bizhub C250 All-In-One...
I need to scan to email using the c353 konica Minolta. I used the same settings that the copier has that is working, but this one i set up won't scan to email.
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Jun 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Jun 04, 2009 | Konica Minolta Office Equipment & Supplies
I can't scan.
The Scanning feature must resolve the name you have entered into the host location in the one touch screen. If the system is not able to resolve the name to an address it will fail. The easy way out of this is to enter the destination IP address. The hard way is to fix the reason the printer can not resolve destination name to an Ip address. That will require fixing a DNS problem on your network
Mar 27, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Canon IR C3100N Scanner Setup
Hi Its fair simple, if you are scanning to windows PC, Create a folder called scans in your C:\ drive. Share it and give all the permissions. Thereafter log on to your copier using the IP address in your internet explorer. Go to address, click address book one, click the second tab on your left saying register new address. thereafter enter you name, then change from FTP to SMB and then host name will be your computer name\ip address, followed by scans(\\computername\scans)just like that. followed by your username and password.
Thanks
Mar 12, 2009 | Canon imageRunner C3100 Copier
Changed email hosting, now scan to email does not work
I'm confused. Are you saying that the programmed addresses don't work, but if you manually enter an address you can send?
Was your Gmail ( or another Gmail) account formerly the account to which the machine's settings were associated?
In order to use the scan to email, whatever settings have changed in your main email account, for example: username, password, SMTP & POP servers, etc, must be changed to match.
I am prettty sure you may have some difficulty, however if your new host uses Email encryption (SSL) , because I don't think that machine is compatible, so you may have to (somehow) configure an extra email account within your Outlook, or whatever you use that does not require authentication.
Feb 23, 2009 | Ricoh Aficio 2015 Copier
I cannot upload via FTP, I have a motorola sgb900
Set up a port trigger for FTP in the "Gateway" section on the "Port Triggers" page. Click on the "Custom" link at the head of the page.
Enter these values
Name FTP
Enable checked
Protocol TCP
Port Range 21:21
Session Chaining TCP/UDP
Session Interval 600
Address Replace Disable
Multi Host Yes
Click Add, then Apply.
You should be all set. Either that, or you could turn off the firewall.
Jan 13, 2009 | Arris SURFboard SBG900 Wireless Router...
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
FTP Server configuration
GO HTTP://192.168.1.254/TECH PASSWORD ADMIN AND YOU CAN RESET EVERYTHING ON YOUR ROUTER WHAT EVER YOU WANT I HAVE SAME ROUTER BUT UPGRADED
Jan 22, 2008 | 2wire HomePortal 1800HG Router...
Brother MFC-8460N All-In-One Printer Logo
225 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
