Question about Minolta Office Equipment & Supplies
Error sc22-02 in minolta di650 - Minolta Office Equipment & Supplies
    Problem Solver:
Code sc90-01
Posted on Jan 29, 2011
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Minolta di650 error code sc50-01
If powering off then on the machine does not clear this code it is a fault with the serial drive signal from Printer control Board! Quite Expensive! Or main dive section of the machine. Recommend a Certified Tech look at it, sir/mam
Mar 14, 2014 | Konica Minolta Start Up Kit for DI650...
Code d'erreur sc29-03 minolta di650
Sir/Mam,
When was the last time your machine had a 250,000 Preventive Maintenance kit installed. Very 250K copies/print the Developer and certain parts need replacement, the drum at 500K. The code your machine has is telling you that either the drum is bad a sensor/sensor board is bad, or the drum is old and needs replacement. Also possible the sensor needs to be cleaned. Have to remove the drum cart then the drum to get to it. Recommend a tech do it.
Aug 01, 2013 | Konica Minolta Start Up Kit for DI650...
Problem 3725 konica 650
Sir is this a C-3725 or SC-37-25. And the Model is Di650 or 650???
Apr 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Minolta di650 error code sc90-01
Sir, Mam
The middle section of the that you pull out to get paper jams will the circuit board the controls that section or a major board is bad you mite want to check for any paper that left a part of stuck inside that area of the machine look in the back (When you pull it out) IF not you Need a Technician!!! Not a normal code!!!!!!!
Feb 03, 2011 | Konica Minolta Start Up Kit for DI650...
Minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Oct 23, 2008 | Office Equipment & Supplies
146 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
