Question about Toshiba Satellite M55-S331 Notebook
My computer shut off while moving pictures to an external hard drive. When I tried to turn the computer back on, I get the following message: We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this. If your computer stopped responded, restarted unexpectedly, or was automatically shut down to protect your files and folder, choose Last Known Good Configuration to revert to the most recent settings that worked. If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose Start Windows Normally. Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Last Known Good Configuration (your most recent settings that worked) Start Windows Normally I have selected all of these at some point or another. But, the computer tries to boot up only to come back to this screen in about 10 seconds. Is this a fixable problem?
  • 655 Answers
SOURCE: Laptop won't comeback on
1. select safe mode command prompt
2. type SCANREG and press enter key
3. follow the screen instruction
4. select the old one date when your computer was working well, from the restore list appeared.
5. reboot
and finally.............:))
Posted on Mar 31, 2008
  • 2028 Answers
SOURCE: Windows wx start up failure
The shut down caused a system glitch. You will need to run a system repair with your recovery or operating system disc. Rare, but occasionally, the hard drive crashes under these circumstances and will need to be replaced. Usually if this happens, the hard drive was on it's way out anyway, and would have crashed eventually.
Posted on Jul 02, 2008
SOURCE: Toshiba Satellite M30
You can try to select safe mode and do a system restore (Start-all programs-accessories-system tools-system restore) choosing the date when your laptop was working properly. If you are using Vista, you would see if you had a Windows Update or other such software changes. It is like undoing that but there would be no changes with your personal data. If your laptop works faster after that, please do not have the same software or update again. Hope this helps. Thank you.
Posted on Oct 04, 2008
  • 3866 Answers
SOURCE: My computer won't boot.
This would be a good time to recover or roll back what you did, There must have been a change in your configeration.
Posted on Jun 09, 2009
  • 1098 Answers
SOURCE: The screen says "We apologize
If you can go to SAFE MODE, go into Control Panel and go to "System" and then the "Advanced" tab. Click "Settings" under Start up and Recovery. Then uncheck "Automatically Restart".
This will let you see that Blue Screen so you can research the error. Then restart.
The first thing I would do is remove any new hardware that might have been installed, unplug any external devices like printer, scanner, camera, etc... and then try it.
If that doesn't work, pop in your recovery disk. It will help you through the entire process of the repair.
Let me know what happens.
Thank you!
Posted on Jan 19, 2011
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Proper or Best way to use my newly installed WD SATA external Hard Drive;
The files are placed on the drive by you. Unless someone setup a special application files will not automatically migrate to another drive. You would not generally want them to because they would never be where you left them and be much harder to find. Primarily you will want to be moving data files and not application files (unless you uninstall from the internal drive and reinstall to the external drive) You can open my computer and find both drives -- you can drag/drop folders (containing only data, mp3s, videos, etc) between drives. I always like to check these moves by doing a right mouse click selecting properties on each folder separately to assure that an equal number of folders and files were copied before deleting them off of the smaller drive.
I emphasize again moving programs in this fashion will cause them to break. If you have large and seldom used applications you can uninstall them then using the installation process and media provided by the manufacturer then reinstall them choosing the external drive as the destination..
I hope this helps.
Dec 09, 2007 | Western Digital Caviar SE WD800JD SATA...
Hello, I have a Maxtor 500gb external hard drive since 3 years now. Since last week he computer recognises it but after few minutes it it shuts down with the error message coming up as 'Not...
Hello, please try the following:
1. Try changing your drives usb cable 2. Run a disk check on your drive to fix any errors. If the problem remains then its a sure sign your drive is about to fail, backup or recover your data quickly using drive recovery software.
All the best, thanks for using FixYa.
Jul 23, 2011 | Computers & Internet
Needs a space for local disk (D). what should i do?
- Empty recycle bin - Remove any temporary files - Remove any cached or page, swap files
Mar 17, 2011 | Computers & Internet
I dropped my drive and now the computer won't recognize it. The blue light is on with the red light. Help!
Sorry to hear that your drive is having trouble. When you start the drive, do you hear it turning?
Is this a external that you can remove the hard drive? You may try to power down the external, power it back up and shut down your computer. The conect the external and turn the computer on.
Let me know if you can hear the driver turning and it you can connect after going thru the process above.
Feb 05, 2011 | SimpleTech Signature Mini 320GB External...
Can't turn off Hard Drive
The error means that you are using a file on the external hard drive and that it can not close that file when it is use. You have to close the program that is using the file first.
Lets go on the assumption that you have your music collection on the external. If you still have your music player running when you try to disconnect, you will be greeting with the same error message.
If the external contains any files that your Operating System uses, you will get this message anytime the computer is on. An example of this can be your "Page File".
Shutting the computer down correctly is your safest bet until you find exactly what file is being used and what program is using it. During shut down, the computer closes any running programs. With no programs running, it will safely disconnect from the external HD because there will be no files in use.
If you manually disconnect it while the file is in use, you could very easily corrupt the file and make it unusable. This is comparable to an Operating System getting corrupted from a computer not being shut down correctly (pulling the power from wall without doing a shut down).
Hope this helps.
May 02, 2010 | Western Digital My Book Essential Edition...
Simpletech 1TB USB not recognised properly
I had a very similar problem. It turned out to be a faulty case.
If the drive was formatted, there is a very good chance you've destroyed your data and may need professional services to recover the files (if possible)
Chances are you just needed to replace the external case by removing the harddrive from the simpletech case and installing it in a new case.
But again, if the drive's been formatted, it may have wiped out your data.
Jan 22, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
WD External Hard Drive malfunctioned & is not recognized
you can **** in western digital factory with this ugly hard drive
Dec 24, 2008 | Western Digital My Book (WDG1U2500)...
Corrupt External Hard drive
I have a 250 g I moved all my pictures from my pc to it and now the hard drive will not open. It is nearly full. It acts like there are no files on it. What should I do, unplug it?, restart the pc, plug it into another usb port on the of my pictures are gone!!!!!..........RB
Mar 23, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How to transfer files and programs etc..using Seagate 500 GB..
I understand that you are trying to move data from your computer to an external hard drive.
You can just copy and paste the files like Music, Pictures to the external movies when it is connected to the computer. The hard drive owuld be listed as an removable storage device icon in the My Computer window if you are using windows XP.
However, we cannot just copy and paste the programs in the hard drive. You need the installation files to be copied to the external hard drive, if you want them to eb backed up.
Mar 07, 2008 | Computers & Internet
Toshiba Satellite M55-S331 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
